Re: E-mail
I have no experience with Windows Messenger.
I do not use it and I have not interested to get acquainted with him.
Maybe someone else can do something about this matter.
Re: E-mail
Hopefully someone could pick this up, would be nice feature...
I am still discovering your plugins by reading through the forums (just found the excellent Scheduleghost - thanks), do you have your own web page or one place where we can see all your plugins??
Regards, J
Regards, J
Re: E-mail
Unfortunately not, this web page I have not created. I never thought about it. But now I think about it. Maybe.jofan wrote:do you have your own web page or one place where we can see all your plugins??
Re: E-mail
Thank you for this great plugin.
Unfortunately I can not find any function to attachment on an e-mail.
If an event is triggered ,an email with a specific file be sent.
Is it possible to incorporate this feature?
Using this function I would be very happy.
Many thanks,
Asuries
Many thanks,
Asuries
Re: E-mail
Thank you for the appreciation.Asuries wrote:Hi Pako,
But the truth is that this plugin would need revision. Certainly contains a lot of bugs because I was a beginner when I wrote this plugin.
Yes, I have already considered the possibility Incorporate this feature.Asuries wrote: Unfortunately I can not find any function to attachment on an e-mail.
Using this function I would be very happy.![]()
I'm now working on another new plugin. Once I finish it, I'll work on the attachement feature.
Re: E-mail
Pako,
I second the attachment feature.
I would love to be able to download an attachment to a folder.
I found a script that can send an attachment through a gmail account. I successfully sent an mp3 file.
This was the only script I found that gmail correctly decoded the attachment.
Carson
Carson
Re: E-mail
Yes, I plan to add this feature.
However, E-mail plugin requires extensive revision.
Without this revision is not possible to add any other features.
I do not know when I'll do.
Re: E-mail
No worries, I understand.
Let me know if you need me to test some code when the time comes.
Re: E-mail
Dear Pako,
thank you very much for the E-Mail plugin. I like it very much.
Unfortunately I cannot connect via TLS to my SMTP server, it always refuses the connection.
Out of desperation I changed the code in line 2293 from
to
and it works now! I don't really understand why it works, but it does - very reliably. Maybe the original datatype is unicode and some character conversion fails otherwise?
I just wanted to let you know about this oddity.
Thank you and best regards!
password = self.passSMTP.data[server[0]]
password = str(self.passSMTP.data[server[0]])
Re: E-mail
Pako,
Would it be possible to add a selection box for the "Event name:" text. For example, similar to "Payload:" selection box. Screen shot attached.
I wanted to use email "Subject" or "From" as the event name suffix. And have the payload as email "Body".
kalia
kalia
- Email: Start Observation
- email.PNG (11.4 KiB) Viewed 10175 times
Re: E-mail
Yes, this possibility I may add, it should be relatively easy.kalia wrote:Would it be possible to add a selection box for the "Event name:" text. For example, similar to "Payload:" selection box. Screen shot attached.
Please be patient.
Re: E-mail
Great news Pako,
I will try this out this weekend. Does your plugin already support attaching files to sent emails and downloading files from received emails?
regards,
Perry
regards,
Perry
Re: E-mail
No, there is only added a selection box for the "Event name" (demanded kalia).piert wrote:Does your plugin already support attaching files to sent emails and downloading files from received emails?
Perry
