SoundMixerEx
brand10
Re: SoundMixerEx
Post by brand10 »
This plugin seems not to work with Windows7 perfectly... Any updates?!
thahim
Re: SoundMixerEx
Post by thahim »
dexter98 wrote:This thread is for support on the SoundMixerEx plugin.
This plugin is an extension of the standard SoundMixer controls in EventGhost and allows you to setup virtually ANY slider and on/off switch (eg mute, digital out on/off) on one or more sound cards.
Multiple controls can be controlled on multiple sound cards through the same plugin. I personally use this plugin to switch on/off the 'digital out only' feature on my Audigy to be able to output (analog) sound, even when pass-through is active (which normally blocks any sound output other than the DD/DTS source).
Adding this plugin just hangs my event ghost and i have to force close.
What should I do?
i'm running windows 7
EventGhost Version 0.4.1.r1669
Windows 7
yasuo
Re: SoundMixerEx
Post by yasuo »
Hi there,
i want to shange my sound ouput from my laptop speakers to hdmi and vice versa.
but no soundcards are visible under Windows7 / Lenovo Y700
is this plugin depricated? is there another option to wtich output devices?
Re: SoundMixerEx
Post by Sem;colon »
Hi Yasuo,
viewtopic.php?f=9&t=6213
That's what you want ;-)
yasuo
Re: SoundMixerEx
Post by yasuo »
Sem;colon wrote:Hi Yasuo,
working. Thank you!
