RFXtrx
b_weijenberg
Re: RFXtrx
KD101 smoke detectors get te same address if they are connected/paired.
SD90 smoke detectors have a configurable unique address.
The KD101 can also be controlled by the RFXtrx433 and can function as a siren.
Re: RFXtrx
They are KD101, so they should have one address, then. And yes, it was the siren function I was after. My son's going to work this summer and live in the cabin, and I was thinking about waking him up with an inferno of smoke alarms!
Even a teenager shouldn't be able to sleep through that!
Edit: Next step will be to put the wires from an electrical cattle fence underneath his sheet, so if he doesn't get up within 10 seconds after the siren has started, he will be zapped up!
Re: RFXtrx
Hi!
I noticed a bug in the part handling AC (lighting2) where your choices for the Unitcodes go from 0-15 but your Unitcodes array only contains 1-16 (as it should).
Change
to
on line 3229 and it should work.
Also how come the 'group' value is there?
Thanks for a great plugin!
Change
list = [
'0', '1', '2', '3', '4', '5', '6', '7', '8',
'9', '10', '11', '12', '13', '14', '15', 'group'
]Code: Select all
list = [
'9', '10', '11', '12', '13', '14', '15', '16'
]Also how come the 'group' value is there?
Re: RFXtrx
Excellent, thank you!
I will fix this in the next upcoming version where I am currently also adding support for new device brands.
Re: RFXtrx
New version uploaded in first post
Re: RFXtrx
thanks for this plugins !
can you add support to the OWL 119 power meter ?
Re: RFXtrx
Regarding OWL CM119/160, can you try this version? I am not 100% sure it will show everything correct. Please check if the readings are looking ok.
Re: RFXtrx
Hi
Thx for your answer.
It doesn't work. The frame isn't decoded. see the log :
another frame decoded by rfxmngr:
ask me if you need something
Unknown message: ['11', '5a', '01', '0a', '51', '82', '00', '00', '00', '02', '53', '00', '00', '00', '9d', '52', '87', '69']
('Debug Info: ', 17, 36, '115a010a518200000002530000009d528769')Code: Select all
115A0106518200000002530000009D2F9D69
Packettype = ENERGY
subtype = ELEC2 - OWL CM119, CM160
Sequence nbr = 6
ID = 20866
Count = 0
Instant usage = 595 Watt
total usage = 46056,8034479984 Wh
Signal level = 6
Battery = OK
Re: RFXtrx
Thanks for the debug info. I think I found the problem. Could you try this version?
Re: RFXtrx
Thanks for your answer
here is my config in rfxmngr :
i have to set up manually "Mertik" in rfxmngr, then quit and lauch eventghost to recieve OWL's frames
now the frame are identified by the eventghost plugings, but not well decoded (very huge id !) :p
i also got some errors
0D01000203532A000FEF00000000
Packettype = Interface Message
subtype = Interface Response
Sequence nbr = 2
response on cmnd = Set Mode
Transceiver type = 433.92MHz
Firmware version = 42
Hardware version = 0.0
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU enabled
Ikea Koppla disabled
Oregon Scientific enabled
ATI enabled
Visonic enabled
Mertik enabled
AD enabled
Hideki enabled
La Crosse enabled
FS20 disabled
ProGuard disabled
RollerTrol disabled
RFU protocol 7 disabled
------------------------------------------------now the frame are identified by the eventghost plugings, but not well decoded (very huge id !) :p
['11', '5a', '01', '02', '51', '82', '00', '00', '00', '02', '33', '00', '00', '00', 'b6', 'e8', '0f', '69']
RFXtrx.Type: CM119/160 id: 2627942893704725676029896796142196564124583972389099125059822912882946074351233668867988895958192680717840218186966577773451228151155214665991168344648594505056477933679817470425616080596391474849110004664831470963872797826562208877536763624324085768148945130932646358311046171321551139636416496267583609702676139675169265680138524067349815345275833985366771036063926973144659447576480914016548086986790496833055555163553039506537880037231870311661627740031393898144022267443778697524944539848665285974381389250794107013259269801398305018674655411177456363097380917177817447380099309695499167627221859531289928578191746 ' Counter: 0 Instant power usage: 563.00 W Total energy usage: 53593.12 Wh signal: 6 battery: 9'
('Debug Info: ', 17, 36, '115a010251820000000233000000b6e80f69')
Unknown message: ['04', '00', '00', '01', 'd2']
('Debug Info: ', 4, 10, '04000001d2')
Message is incomplete: 0 2 00
['11', '5a', '01', '05', '51', '82', '03', '00', '00', '02', '33', '00', '00', '00', 'b6', 'eb', '48', '69']
RFXtrx.Type: CM119/160 id: 2627942893704725676029896796142196564124583972389099125059822912882946074351233668867988895958192680717840218186966577773451228151155214665991168344648594505056477933679817470425616080596391474849110004664831470963872797826562208877536763624324085768148945130932646358311046171321551139636416496267583609702676139675169265680138524067349815345275833985366771036063926973144659447576480914016548086986790496833055555163553039506537880037231870311661627740031393898144022267443778697524944539848665285974381389250794107013259269801398305018674655411177456363097380917177817447380099309695499167627221859531289928578191746 ' Counter: 3 Instant power usage: 563.00 W Total energy usage: 53596.81 Wh signal: 6 battery: 9'
('Debug Info: ', 17, 36, '115a010551820300000233000000b6eb4869')-
Re: RFXtrx
I was making another bug
Now, this version should also show the id correctly
Some errors of type "Message is incomplete" and "Unknown message" could be fully normal, all depending on your environment and what the receiver is picking up
Re: RFXtrx
thanks for this version. It works nice, but there is one more thing
The RFXTRX seems not beeing initiated to recieve the OWL frames. I have to setup first with rfxmgr provided by rfxcom, and then run EventGhost. Is there any way to initiate it directly with evenghost ?
b_weijenberg
Re: RFXtrx
OWL is enabled when the Oregon protocol is enabled.
An updated RFXtrx firmware version 43 with a change for the OWL has been uploaded today.
Re: RFXtrx
Nice ! I just upgraded the firmware and confirm that now the OWL is directly listened by the rfxtrx.
I can see some differences between the data displayed by the OWL and the data decoded by the rfxtrx :
RFXmgr decode :
But the total usage is 98,765KWh and the instant usage is 419W. The difference is not so big, but it could be great to have the good data
RFXmgr decode :
115A0113518200000001A200000150FAB379
Packettype = ENERGY
Sequence nbr = 19
ID = 20866
Count = 0
Instant usage = 418 Watt
total usage = 98737,7384135273 Wh
Signal level = 7
Battery = OK-
b_weijenberg
Re: RFXtrx
The difference is a rounding problem. Do not expect that the OWL and RFXtrx display the same value.
You have to know that the OWL is never able to receive a correct power usage value because the voltage is a fixed parameter and for a real power value you would need the line voltage. If you want a power usage measurement comparable with the utility meter (2% accuracy) you should use an RFXMeter.
