Tornado (webserver with WebSocket)
m19brandon
Re: Tornado (webserver with WebSocket)
Pako, is the only change with 2.0 support for WebP?
Yes.m19brandon wrote:Pako, is the only change with 0.2 support for WebP?
Hi everyone,
I just now tested the tornado plugin (I wanted to do that for months now, but I haven't found the time)
Besides some first difficulties, I finally managed to get it running - and it's awesome!
Anyway, my question is: Does somebody manage to get rid of this "it works!" page?
I don't want to type "ipToServer/index.html" to actually enter the site.
Thank you in advance!
Hi Sem;colon!
I was confused by your response to the Tornado plugin.
It seemed that you completely ignore it.
It is very unlikely that someone else will respond.
Well, I can add the optional parameter "Default document".
If it is filled, then just this one document will be open instead of "It works!".
It will be okay this way?
I think you could easily appeal directly to me.Sem;colon wrote:Hi everyone,
Well, you did not have time.Sem;colon wrote:I just now tested the tornado plugin (I wanted to do that for months now, but I haven't found the time)
I'm very pleased that you are so excited.Sem;colon wrote:Besides some first difficulties, I finally managed to get it running - and it's awesome!
I'm sorry, that does not suit you, "It works !" page.Sem;colon wrote:Anyway, my question is: Does somebody manage to get rid of this "it works!" page?
New version (0.3) released.
New:
New:
- "Default document:" optional parameter added
Hi Pako!
Thank you, I'm sure others will appreciate this as well!
I spent the day yesterday trying to replace the webserver plugin in my config with the tornado plugin - but it wasn't successful, my web interface in quite complex and has lots of dependencies. It seems that some things are not working that worked with the webserver plugin (I don't get any errors, it's just not working) e.g. $.get() seems to not work at all.(jQuery v1.10.2)
The Tornado webserver also stops responding while loading the page. After all, the webserver plugin seems to be more stable...
True, but I still wanted to give them the chancePako wrote:I think you could easily appeal directly to me.
That's exactly what I had in mindPako wrote: Well, I can add the optional parameter "Default document".
Yes, it is more than likely that some query options are not functional.Sem;colon wrote:It seems that some things are not working that worked with the webserver plugin (I don't get any errors, it's just not working) e.g. $.get() seems to not work at all.(jQuery v1.10.2)
It was impossible for me to try everything.
Can you please attach some files (as small as possible), so I could try dysfunctional query options?
I suppose it will be easy to fix the problem.
In this case, I'm not sure whether it will be possible to repair it.Sem;colon wrote:The Tornado webserver also stops responding while loading the page.
You can also provide a concrete example, so that I might test?
EDIT:
It seems that I found the problem.
Can you please test the GET method?
Test version 0.3a attached.
Thanks, Pako
- __init__.py
- (124.03 KiB) Downloaded 163 times
Attached!Pako wrote: Can you please attach some files (as small as possible), so I could try dysfunctional query options?
Not yet, I don't know where it stops working - I need to do more testing (it's not easy to debug this...)Pako wrote: In this case, I'm not sure whether it will be possible to repair it.
At least with this version $.get() seems to work with .html suffixed files (I didn't test that with version 0.3! Maybe it was working there as well)Pako wrote: It seems that I found the problem.
I my case I have a file that's .json suffixed, here $.get() still isn't working. (the .json is not a most, but I was using it this way with the webserver plugin)
I attached some simple files with witch you can check that.
- test.zip
- (32.33 KiB) Downloaded 148 times
So it was easy.Sem;colon wrote:I my case I have a file that's .json suffixed, here $.get() still isn't working.
That was enough to add extension ".json" to mimetypes.
- __init__.py
- Test version 0.3b
- (124.18 KiB) Downloaded 181 times
ah, ok, thx!
...Then you should maybe add .htm as well, as this is a very common suffix - or make the mimetypes configurable.
It's already there.Sem;colon wrote:Then you should maybe add .htm as well
I checked it out.
Check is easy:
1) Open the PyCrust window (Python Shell)
2) Write the commands tp = eg.plugins.Tornado.plugin and em = tp.extensions_map
3) Now you can type print em or print ".htm" in em etc.
For some reasons I can't get the sliders to work correctly in chrome or stock browsers on my android devices. It does work perfectly in Dolphin browser thou.
If I use chrome or the stock browser the slider moves but no event is sent to EG. But if I manage to press just above or beneath the slider it registers and send a event to EG.
Do you have any idea what can cause this?
m19brandon
Pako, can this be done. I'm parsing the event currently but would prefer a payload. I'm sending longer search queries.m19brandon wrote:With the Send Event to Another Eventghost server can I added a payload? I do not see it in the py either.
New version (0.4) released.
News:
News:
- first version for release r1669 and later (no need to install libraries)
- Common handler: get method fixed
- mimetype >>> '.json': 'application/json' <<< added
