Has anybody done anything with Sensibo Sky?
- kgschlosser
Re: Has anybody done anything with Sensibo Sky?
the patch method does not work. from browsing the information and code I could find post is used and not patch. have you tried the script they provided as is?
I'm not sure what your looking at. This is the sample client. It would need only slight modification to work within an eg script. It would be faster to insert into a plugin though.
import requests
import json
_SERVER = 'https://home.sensibo.com/api/v2'
class SensiboClientAPI(object):
def __init__(self, api_key):
self._api_key = api_key
def _get(self, path, ** params):
params['apiKey'] = self._api_key
response = requests.get(_SERVER + path, params = params)
response.raise_for_status()
return response.json()
def _patch(self, path, data, ** params):
response = requests.patch(_SERVER + path, params = params, data = data)
def devices(self):
result = self._get("/users/me/pods", fields="id,room")
return {x['room']['name']: x['id'] for x in result['result']}
def pod_measurement(self, podUid):
result = self._get("/pods/%s/measurements" % podUid)
return result['result']
def pod_ac_state(self, podUid):
result = self._get("/pods/%s/acStates" % podUid, limit = 1, fields="status,reason,acState")
return result['result'][0]['acState']
def pod_change_ac_state(self, podUid, currentAcState, propertyToChange, newValue):
self._patch("/pods/%s/acStates/%s" % (podUid, propertyToChange),
json.dumps({'currentAcState': currentAcState, 'newValue': newValue}))
if __name__ == "__main__":
import argparse
parser = argparse.ArgumentParser(description='Sensibo client example parser')
parser.add_argument('apikey', type = str)
parser.add_argument('deviceName', type = str)
args = parser.parse_args()
client = SensiboClientAPI(args.apikey)
devices = client.devices()
print "-" * 10, "devices", "-" * 10
print devices
uid = devices[args.deviceName]
ac_state = client.pod_ac_state(uid)
print "-" * 10, "AC State of %s" % args.deviceName, "_" * 10
print ac_state
client.pod_change_ac_state(uid, ac_state, "on", not ac_state['on']) - kgschlosser
I know of their example, But there are other people who have written bits of software to connect to these things. and not a single one of them use the patch method. I would guess this is because it is problematic?, IDK. I am able to find libraries made on several different programming languages. but only the one for python.
This can be tried to see if it works. I believe it should.
import requests
import json
data = dict(
on='on',
mode='heat',
targetTemperature=27,
temperatureUnit='celsius',
swing='rangeFull',
fanLevel='medium_high'
params = dict(
apiKey=eg.globals.sensiboKey,
fields="acState"
response = requests.post(
'https://home.sensibo.com/api/v2/pods/oohZomrQ/acStates',
data=json.dumps(data),
params=params
print response.content
print json.dumps(response.json(), indent=4)
That will likely work. I don't think patch would be a problem either. It was the way i was formatting the data. Seeing that example shows me where my error was.
- kgschlosser
I didn't look to close at the patch method. But at a glance what you had done looked the same as in the example they gave. Not sure tho.
- kgschlosser
ok you can give this a try. I have attached a file that is a python file. you can run this without installing python. (well you actually already have it installed.
This has to be done using EG 0.5
Download the file
open a command prompt
navigate to where you saved the file.
if you have EG installed in it's normal location enter this command, or modify it's path accordingly.
replace the {api_key} with your api key
The api key always has to be there. if you want to print out the device information add the --device-name {name} switch
command line switches are listed below. any of the options that have set in them you will need to make sure that you enter the appropriate item from the device capabilities that gets printed out. EXCEPT for set-power, use on or off for this switch
--list_devices
--device_name {DEVICE_NAME}
--set_temp {TARGET_TEMP}
--set_swing {SWING}
--set_power {POWER}
--set_mode {MODE}
--set_fan {FAN_LEVEL}
Download the file
"c:\program files (x86)\eventghost\_py" test.py {api_key} --list-devices
--list_devices
--set_swing {SWING}
--set_power {POWER}
--set_mode {MODE}
- test.py
- (13.07 KiB) Downloaded 50 times
The first part, getting the list doesn't really send back anytyhing but the API key:
And when I tried --set-temp, I got this:
I'm sure I'm doing something wrong...
D:\>"c:\program files (x86)\eventghost\py" test.py {My API key} --list-devices
{My API key}
None
True
None
None
None
None
None
---------- devices ----------
File "py.py", line 29, in <module>
File "D:\test.py", line 389, in <module>
for dev in client.device_names:
File "D:\test.py", line 328, in device_names
return sorted(self.devices.keys())
File "D:\test.py", line 342, in devices
result = response.json()
File "c:\program files (x86)\eventghost\lib27\site-packages\requests\models.py", line 812, in json
return complexjson.loads(self.text, **kwargs)
File "json\__init__.pyc", line 339, in loads
File "json\decoder.pyc", line 364, in decode
File "json\decoder.pyc", line 382, in raw_decode
ValueError: No JSON object could be decodedCode: Select all
D:\>"c:\program files (x86)\eventghost\py" test.py {My API key} --set_temp {20}
usage: test.py [-h] [--list-devices] [--device-name DEVICE_NAME]
[--set-temp SET_TEMP] [--set-swing SET_SWING]
[--set-power SET_POWER] [--set-mode SET_MODE]
[--set-fan SET_FAN]
api_key
test.py: error: unrecognized arguments: --set_temp 20- kgschlosser
oooops heh.. they are '-''s not '_'s my typo. sorry!!!!
- kgschlosser
but it is still not going to work..let me modify it so we can see hat the error is that it is spitting out.
D:\>"c:\program files (x86)\eventghost\py" test.py {My API key} --set-power {on}
{My API key}
None
False
None
None
{on}
None
None
- kgschlosser
This is still not going to work. but it will print out the error for me.
- test.py
- (13.05 KiB) Downloaded 40 times
- kgschlosser
no curly braces {}... just on or off. but as i said. it is not going to work until i find out why it is not getting a device list
- kgschlosser
well that is probably why too. you are putting {}'s around your api key.. don't
"c:\program files (x86)\eventghost\py" test.py APIKEY --set-power on
- kgschlosser
and this is actually not a correct command because you did not tell it what device you want to turn on.
it should be this
anything you want to do that is device specific you need to tell it the device.
to list the devices names then use the --list-devices with only your api key
"c:\program files (x86)\eventghost\py" test.py APIKEY --device-name DEVICENAME --set-power on
As I said I tried with that too, but it didn't change anything. And I see why. It's not parsing the key correctly.
It's adding %7B to the beginning, and and it adds %7D to the end.
<html><head><title>403 NotAuthorized - Sensibo</title></head><body><h>403 NotAuthorized</h><p>Invalid API key</p><body></html>
File "D:\test.py", line 401, in <module>
dev = getattr(client, args.device_name)
File "D:\test.py", line 361, in __getattr__
devices = self.devices
File "D:\test.py", line 346, in devices
", line 844, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 403 Client Error: Forbidden for url: https://home.sensibo.com/api/v2/users/me/pods?fields=id%2Croom&apiKey=%7B[b]MY API KEY[/b]%7D
