New Pioneer AVR Network Plugin
3000
Re: New Pioneer AVR Network Plugin
Post by 3000 »
awesome, thank you very much!
sign my petition to save a 28-year-old young mother who is fighting Stage 4 cancer: https://www.change.org/p/help-cancer-pa ... on-the-nhs
kkl
Post by kkl »
There is one particular error message I get fairly frequently that comes through as an Info item rather than Event:
Pioneer_AV_NET: ERROR: [Errno 10054] An existing connection was forcibly closed by the remote host
Usually if I reissue the command, it goes through. Any idea how I can trap for this so I can try again? Thanks.
Post by Sem;colon »
Hmm, I'm surprised that you even get that Error, is your connection unstable (W-LAN) or are you using other tools to control the AVR from time to time?
kkl
Post by kkl »
Hi. The connection is hard-wired ethernet. I use this plugin from two different PCs to control a VSX-1123, but very separated in time (usually hours).
piert
Post by piert »
I am not sure about your Pioneer type receiver, but I believe mine (VSX 2021) has a feature to keep the LAN connection alive. This is less energy-efficient, but might keep your connection alive?
kkl
Post by kkl »
Yes, Network Standby which I have ON. Thanks for the feedback Piert.
Post by Sem;colon »
New version!
v0.9:
-Some minor fixes
-Plugin is now in the .egplugin format
Get it from the first post!
