Has anybody done anything with Sensibo Sky?
- kgschlosser
Re: Has anybody done anything with Sensibo Sky?
You need to remove the {} from the api key.
Yes, I did!
I need it in with teaspoons, you se...
But now list devices really works, I see "Varmepumpe ovenpå". I can't use the ID as the name, though. That fails, and I would like to keep the name as it is. Can you please make the script unicode aware?
- kgschlosser
HOLY COW!
you are sure asking a lot there boss...
- test.py
- (13.05 KiB) Downloaded 37 times
- kgschlosser
I have to leave for a few hours i have some errands to run. I should be back in 2-3 hours
No problem at all, I'm not in a hurry. You will have time, I will probably be in bed when you get back, I have to get up early tomorrow morning.
- kgschlosser
Not sure if you know this or not. But there is a script attached to my 2nd to last post with the unicode problem hopefully sorted
I didn't! Sorry... I keep overlooking your short, quick mesages...
Yeah, guess I'm asking a lot.
Let me know if it's impossible...
I ran it, and without "" around the name of the device, Varmepumpe ovenpå, I get this:
With "" around the device name, "Varmepumpe ovenpå", I get this:
test.py: error: unrecognized arguments: ovenpÕCode: Select all
test.py: error: argument --device-name: invalid unicode value: 'Varmepumpe ovenp\xe5'- kgschlosser
ok i am going to have to do the good ol encode/decode thing. it may take me a bit to get it right. for some crazy reason it does every time i mess around with unicode.. you would think I would remember how to do it.
- kgschlosser
give this one a shot.
because you have a space in the device name you are going to have to use the double quotes
- test.py
- (13.09 KiB) Downloaded 39 times
- kgschlosser
Nothing is impossible... That word does not exist to me. I may state that it is beyond my present knowledge, or maybe that it is beyond the current state of technology.. But at some point it will/can be done.
For your "syncronized posting": We have a very famous fictional inventor in a Norwegian children's series by the name of Reodor Felgen. His motto is: "The difficult is a trifle, and the impossible only takes a bit more time."
Afraid not. I'm starting to wonder if I should use Varmepumpe-ovenpå instead of Varmepumpe ovenpå, though. The version with the dash gives me this:
Doesn't that seem more promising?
Varmepumpe-ovenpÕ
False
23
None
None
None
None
File "py.py", line 29, in <module>
File "D:\test.py", line 401, in <module>
device_name = args.device_name.encode()
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe5 in position 16: ordinal not in range(128)- kgschlosser
you shouldn't have to change a thing. I think i should have it sorted.
try this one.
try this one.
- test.py
- (13.22 KiB) Downloaded 39 times
D:\>"c:\program files (x86)\eventghost\py" test.py API KEY --device-name Varmepumpe ovenpå --set-temp 23
usage: test.py [-h] [--list-devices] [--device-name DEVICE_NAME]
[--set-temp SET_TEMP] [--set-swing SET_SWING]
[--set-power SET_POWER] [--set-mode SET_MODE]
[--set-fan SET_FAN]
api_key
test.py: error: unrecognized arguments: ovenpÕ- kgschlosser
did you use the "" around the device name?
"c:\program files (x86)\eventghost\py" test.py API KEY --device-name "Varmepumpe ovenpå" --set-temp 23
I tried that too:
D:\>"c:\program files (x86)\eventghost\py" test.py API KEY --device-name "Varmepumpe ovenpå" --set-temp 23
API KEY
Varmepumpe ovenpÕ
False
23
None
None
None
None
File "D:\test.py", line 406, in <module>
dev = getattr(client, device_name)
File "D:\test.py", line 366, in __getattr__
raise AttributeError
AttributeError
