4 what is load artist,album,song grammar? work it on this editon or is it from itunes version?
you don't need this. This is actually for mediamonkey, maybe we will integrate something for WMC later.
@ phrase "artist", I must write all my artist down?
see above. For now, yes, try putting a few artists in the payload list, where I put David. It needs to match the beginning. So "David" will work for "David Bowie", but just "Bowie" will not work.
On ur itunes version computer voice answer artist etc. are this wav files or computer generate?
computer generated (Text to Speech). I did this with eventGhost, but we will see about it later.
phrase dont accept ├ñ,├Â,├╝,├ƒ (many german words use this)
Yes, this is a real problem I will take a look at the code and see what I can do.
need "start/close media player"
there is already a command called window-close.
I still need to create something for Starting external programs. (soon I hope)
@ phrase after comma space?
I don't understand what you mean
command overlay in wmc?
tricky...WMC like some girls, like to be on top. I will look into it.
under phrase "abc" changeable? german, english?
I don't understand what you mean. You can choose what you want for each phrase and you can use more than one phrase for each command by using commas. example: "select, okay, enter, go" . You can't change the command text like "window-close" or it won't work anymore. You have to be careful with payloads too, if you change them it could break something.
best confidence was 72%,intersection 50% it is okay or work on articulation?
I don't know about this. I usually get >90% when I use a good microphone in a relatively quiet environment. Is this using german words and the german recognizer set it windows control panel? You also need to set up your microphone correctly and adjust the volume. Turning down the input volume can sometimes help.
