Not sure which is best, as each seems to be used.
First off, great work with this plugin.
I'm sure the issues I'm having are with my lack of experience with EventGhost and/or HDMI-CEC. I was wondering if you could help point me in the right direction?
I've spent the past 1-2 hours scouring the forums and google but just can't seem to get the right context.
First off, here is a shot of my Plugin settings:
http://screencast.com/t/fuQ9mlo0H
Here is my issues:
1) My TV is a Samsung with a number of sources/inputs. I would have figured there would be a command that EG could send that would tell the TV to go to HDMI 2. I found the "Select Source" Action but that seems to only allow selecting the various CEC devices. I must be missing a fundamental thing here. I'd also like to do this with the Receiver. Effectively, I'd like it to work much like, and replace, the Logitech Harmony Remote which has things like "Watch TV" which knows all the devices that need to be on and which inputs they need to be set to. How can I do this?
2) By firing the "RCAware PC-CEC: Standby Device: TV" I would have thought it would turn off the TV. However, EG just pops the entry in the log and then about 10secs later I get this in the log. "HdmiCec.Media Center.Feature Abort.Standby.Refused 'TV'"
When I get EG to fire this same Action but with the Receiver, it works as expected and the Receiver goes into standby.
More details:
Receiver: Toshiba Soundbar SBX4250 (CEC Supported)
LCD TV: Samsung 46" LN46A550P3FXZC (AnyNet+ Supported)
