OpenOffice/LibreOffice Impress
I put the plugin "OOo_Impress" (presentation software) into the SVN trunk. So far, is with a symptom noinclude. I want to first go through the "authorization". I think it is now operating satisfactorily, but perhaps could also be slightly improved?
Here is download link.
Re: OpenOffice/LibreOffice Impress
New version (0.1.1) released.
Simplify the code and modifications for compatibility with OOo 3.0 .
I dusted off this old plugin and I made a lot of changes and improvements.
This allows you to comfortably control a presentation (using LibreOffice or OpenOffice), including files created using MS PowerPoint (*.ppt).
Nowadays situation is completely different and with the massive expansion of smartphones, this option may be useful for more people.
Download link, referred in the opening post, is still valid.
henn9438
Post by henn9438 »
I had the same situation with the PS3 plugin being outdated...
