Zoom Player -> DVD Chapters and MKV Chapters on same button?
Dal
Post by Dal »
Is it possible in EG to detect if ZP is in DVD Mode or not, and make EG act accordingly?
The problem is something like this:
When skipping chapters on a DVD, the macro called nexttrack is used. But when trying to use the same button on the remote, in other words the same macro, on a MKV file, it just skips to the next file. This is not desirable :)
This is of course because the macro used for MKV files is called nextchapter.
Is it possible somehow to have this on the same button?
Something like this then:
IF DVD Mode
then use nexttrack
ELSE
use nextchapter
I guess this would be useful for cycling external subtitles too.
Thank you.
Bartman
Re: Zoom Player -> DVD Chapters and MKV Chapters on same button?
Post by Bartman »
The plugin sends events when switching mode or opening a file
WannaTheater
Post by WannaTheater »
So did you ever figure this out?
I am new to EG, and I guess if the plugin generates events when files are loaded, or mode is changed, I could store the mode in a global variable (if that is possible)... then write a script to perform the decision based on that variable?
