Windows XP+ MCE remote problems
Tippo88
Post by Tippo88 »
Have been trying to set up Eventghost on my XP MCE PC with a standard MCE remote and ir reciever to work with both Windows Media Center and XBMC using this guide http://xbmc.org/forum/showthread.php?t=48667&page=2 and xml file.
Am having the following problems:
1. Any version after 0.3.7.r918 will not install- comes up with errors
2. When I install 0.3.7.r918 and import the xml file everything works fine until I reboot then I get two problems:
Firstly when I try to get Live Tv in media center I get a message saying "Set top box error, Unable to change channel on the set top box as remote sensor is not connected" (If i disable eventghost and reboot LiveTV works fine)
3. If I ignore the Livetv problem and launch XBMC it launches "behind" Media Center
Any help much appreciated.
Tippo88
Re: Windows XP+ MCE remote problems
Post by Tippo88 »
As an update I have also used trying a different xml file with HID disabled and again everything works but the same error when trying to watch livetv.
Tippo88
Post by Tippo88 »
Not making any progress other than to isolate that its the MCE remote plugin rather than Eventghost itself that is causing the problem ( perhaps unsurprisingly) . Any ideas very much appreciated.
Tippo88
Post by Tippo88 »
I fixed the installation problems with a windows update looks like the later releases of Eventghost needs a net framework update.
Still struggling with the " remote sensor not connected error" Very frustrating as everything working perfectly otherwise.
Seems to be a fairly unique error and virtually no information on the net, any ideas of how to troubleshoot would be very much appreciated.
