EG & Hulu Desktop...
Is anybody working on this?
I am...sort of.
My "work" so far is mostly just play so far...Nothing to write home about and not much is on the net about the Hulu Desktop (in terms of documentation-shortkeys and such) but I'm fiddling away.
Skip Forward & Skip Back are giving me some headaches. Seems like the curser/mouse has to be hovering just over the time/slider of the video and then left or right keystrokes work (with the keyboard at least) not so well with my remote and emulation of those keystrokes.
But I'll keep trying.
I think Hulu Desktop is still mostly flash based.
Is flash harder to work well with EG? In terms of post/send messages, find windows etc etc then "normal" programs? Just wondering.
I don't really have a question or an issue...yet.
Just wondering if anybody else has been checking out the new Hulu app.
EG & Hulu Desktop
EG & Hulu Desktop
eventghost.net
Be there or be square.
Re: EG & Hulu Desktop
Hulu Desktop is actually just a Flash/Adobe Air running inside a native client.
From my experience you can control the whole Hulu Desktop with 6 keys.
The 4 Arrow Keys, Enter (for play), and Escape (to go back).
Melloware Inc.
EventPhone iPhone Application
Melloware Inc.
Here is the list
Hulu's Player keyboard shortcuts
Key - player response
Up
Down - Progress Bar / Volume
Left
Right - Progress Bar / Jump or seek
Enter - Play
Space Bar - Pause
OK - Select
Back - Return to video
F - to go to full screen
Escape - Exit Full screen,Return to normal view
or
Exit normal view ,Return to Full screen
Exit Player - ALT + F4
Stop - Space then Esc
Minimize a window - Alt-space-N Alt-space brings up the 'system'-menu.
Maximize a window - Alt-space-X
Restore a window - Alt-space-R
See the attached xml file
Scat
Up
Left
Enter - Play
Space Bar - Pause
OK - Select
or
Scat
- my media computer.xml
- See sections labeled HULU
includes sections for Foobar2000, SageTV, PowerDVD - (102.26 KiB) Downloaded 443 times
Hi Scat,
Thanks for posting/sharing your file. I'll give it a try.
I have my Hulu Desktop set up pretty good right now...all but the Skip Ahead/Back functions. I haven't worked on it in a week or so but will see if I can make it work smooth.
Can't recall exactly why but for some reason the left/right arrow keys (with EG) just would not control the video slider bar in HD.
eventghost.net
i've also been trying to get the seek function to work with hulu desktop.
using a harmony one w/MCE IR receiver.
if i don't use eventghost and set the harmony one to emulate the MCE remote, everything works fine and i'm able to seek (with the little popup window above the progress bar in hulu) when i hold down the left/right buttons.
however, once i start using eventghost to intercept remote commands, i can't get hulu desktop to seek with the popup window. i can still jump ahead, but when i hold down the left/right buttons, it doesn't start seek mode as it should. perhaps eventghost introduces some lag so that the commands aren't sent quickly enough to hulu desktop? i've tried playing with the autorepeat in eventghost but to no avail.
any advice?
any advice?
any advice?
Not from me mojo.
I know that Hulu can be pretty slow and "laggy" and that could mess up what we are trying to do. I don't have mine working as well as I would like but I just deal with it and don't seek much.
I'm using mostly emulate keystroke commands with my Hulu Desktop and maybe, just maybe, it would work better using send messages to window commands. But I don't know jack when it comes to send/post messages.
If you do figure it out please post back what you did.
Thanks & good luck.
Not from me mojo.
Thanks & good luck.
eventghost.net
Hulu w FireFox in Windows7
tweak to your delight
Hulu FF window view...
Hulu Full screen FlashPlayer...
Hulu modes task switching 1...
Hulu modes task switching 2...
<EventGhost Version="1640">
<Folder Name="Hulu FF" id="3529" Expanded="True">
<Macro Name="Up">
<Event Name="X10.Up" />
Window.SendKeys(u'{Up}')
EventGhost.AutoRepeat(0.29999999999999999, 0.10000000000000001, 0.10000000000000001, 0.10000000000000001)
<Macro Name="Down">
Window.SendKeys(u'{Down}')
<Macro Name="Right">
<Event Name="X10.Right" />
Window.SendKeys(u'{Right}')
EventGhost.AutoRepeat(0.59999999999999998, 0.29999999999999999, 0.01, 3.0)
<Macro Name="Left">
<Event Name="X10.Left" />
<Action Enabled="False">
Window.BringToFront()
Window.SendKeys(u'{Left}')
<Macro Name="Maximize">
<Event Name="X10.Pause" />
EventGhost.FlushEvents()
Mouse.MoveAbsolute(1000, 820, None, False)
Mouse.LeftButton()
<Macro Name="Info: {Escape}">
<Event Name="X10.FireFly" />
Window.FindWindow(u'firefox.exe', None, None, None, None, None, False, 0.0, 0)
Window.SendKeys(u'{Escape}', False)
<Macro Name="OK/Enter: {Enter}">
<Event Name="X10.Ok" />
Window.FindWindow(u'firefox.exe', None, u'MozillaWindowClass', None, u'MozillaWindowClass', None, False, 0.0, 0)
Window.SendKeys(u'{Enter}', False)
Mouse.LeftButton()
<Macro Name="Play/Pause: {Space}">
<Event Name="X10.Play" />
Window.FindWindow(u'firefox.exe', None, u'MozillaWindowClass', u'', u'MozillaWindowClass', None, False, 0.0, 0)
Mouse.LeftButton()
Window.SendKeys(u'{Space}', False)
<Macro Name="Skip Forward">
<Event Name="X10.Forward" />
Window.SendKeys(u'{Right}', False)
<Macro Name="Skip backward">
<Event Name="X10.Rewind" />
Window.FindWindow(u'HuluDesktop.exe', u'Hulu Desktop', u'HuluDesktop_Host', u'', u'MacromediaFlashPlayerActiveX', 1, False, 0.0, 0)
Window.SendKeys(u'{Left}', False)
<Macro Name="Volume down">
<Event Name="X10.ChannelDown" />
Window.SendKeys(u'{Down}', False)
Window.FindWindow(u'HuluDesktop.exe', u'Hulu Desktop', u'HuluDesktop_Host', None, None, None, False, 0.0, 0)
<Macro Name="Volume up">
<Event Name="X10.ChannelUp" />
Window.SendKeys(u'{Up}', False)
<Macro Name="Emulate Keystrokes: {Escape}" Enabled="False">
<Macro Name="RW Hulu" Enabled="False">
<Event Name="X10.PreviousTrack" />
Window.SendKeys(u'{Left}', True)
EventGhost.AutoRepeat(0.59999999999999998, 0.29999999999999999, 0.29999999999999999, 3.0)
<Macro Name="FF Hulu" Enabled="False">
<Event Name="X10.NextTrack" />
Mouse.MoveAbsolute(680, 975)
Mouse.GoDirection(90)
Window.SendKeys(u'{Right}', True)
Mouse.GoDirection(180.0)
EventGhost.NewJumpIf(XmlIdLink(-1), 2, False)
<Folder Name="Scat's Hulu Backup " id="3603" Enabled="False">
<Macro Name="Up">
<Event Name="Up" />
<Event Name="USB_UIRT.431F515554F5" />
<Macro Name="Down" Expanded="True">
<Event Name="Down" />
<Event Name="USB_UIRT.431F514544F5" />
<Macro Name="Left">
<Event Name="Left" />
<Event Name="USB_UIRT.431F515150F5" />
<Macro Name="Right" Expanded="True">
<Event Name="Right" />
<Event Name="USB_UIRT.431F404050F5" />
<Macro Name="Select" Expanded="True">
<Event Name="Select" />
<Event Name="USB_UIRT.431F454550F5" />
<Macro Name="Play" Enabled="False" Expanded="True">
<Event Name="Play" />
<Event Name="USB_UIRT.431D051104F5" />
Window.SendKeys(u' {Space}', False)
<Macro Name="Pause" Enabled="False" Expanded="True">
<Event Name="Pause" />
<Event Name="USB_UIRT.431D410554F5" />
<Macro Name="Stop" Expanded="True">
<Event Name="Stop" />
<Event Name="USB_UIRT.431D551154F5" />
Window.SendKeys(u'{Space},{Escape}', False)
<Macro Name="Step backward" Expanded="True">
EventGhost.Wait(0.5)
Window.SendKeys(u'E', False)
<Macro Name="Step Forward" Expanded="True">
Window.SendKeys(u'T', False)
<Event Name="USB_UIRT.431D500444F5" />
<Event Name="USB_UIRT.431D441044F5" />
<Macro Name="Fast Forward">
<Event Name="USB_UIRT.431D001404F5" />
Window.SendKeys(u'F', False)
<Macro Name="Rewind">
<Event Name="USB_UIRT.431D140004F5" />
<Macro Name="Screen Maximize Sscreen">
<Event Name="USB_UIRT.431F504454F5" />
Window.SendKeys(u'{Alt+Space+X}', False)
<Macro Name="Screen Minimize Screen">
<Event Name="USB_UIRT.431F544541F5" />
Window.SendKeys(u'{Alt+Space+N}', False)
<Macro Name="Menu">
<Event Name="Menu" />
<Event Name="USB_UIRT.431F514140F5" />
<Macro Name="Hulu: Exit">
<Event Name="Exit" />
<Event Name="USB_UIRT.431F515144F1" />
Window.SendKeys(u'{Alt+F4}', False)
EventGhost.DisableItem(XmlIdLink(3603))
</EventGhost>Hulu Full screen FlashPlayer...
<Macro Name="Up">
<Macro Name="Down">
<Macro Name="Left">
Mouse.LeftButton()
Mouse.LeftButton()
Mouse.LeftButton()
<Macro Name="Up">
<Event Name="Up" />
<Macro Name="Left">
<Macro Name="Menu">
</EventGhost>Code: Select all
<Macro Name="Switch Mode Hulu FF" Expanded="True">
<Event Name="Task.Activated.FlashPlayerPlugin_16_0_0_235" />
EventGhost.EnableItem(XmlIdLink(5179))
EventGhost.Wait(1.0)
EventGhost.EnableExclusive(XmlIdLink(3424))
<Action id="5179">
Mouse.MoveAbsolute(1919, 820, None, False)
EventGhost.DisableItem(XmlIdLink(-1))
<Macro Name="Switch Mode Hulu">
<Event Name="Task.Activated.firefox" />
<Event Name="Task.Deactivated.FlashPlayerPlugin_16_0_0_235" />
EventGhost.DisableItem(XmlIdLink(5179))
EventGhost.EnableExclusive(XmlIdLink(3529))
</EventGhost>eventghost.net
