Hi folks,
I've recently discovered EventGhost and i am absolutely happy with the useability of this Project.
In the meantime i am stuck in a Problem you might help me out.
First of all my Configuration:
Win xp x64
EventGhost 0.307.r1076
IgorPlug-USB / EZMC USB (because of x64)
Logitec Harmony 555 using DVB-Viewer Profile
Now here is my Problem:
If I press a button for a very short time i get a singe event like IgorPlugUSB.Unknown.XX .
If I hold a button a bit longer there appear two events, first one as before second is always IgorPlugUSB.Unknown.10 .
The green Arrow at the bottom gets red flashes green and returns to red as long the Button is held.
The effect is that the autorepeat marco dosen't work at all.
In order to localize the failure i tryed out some other rc's - all the same.
I also tryed out Girder with the EZMC driver. There the indicator of recieving signal is flickering when a button is pressed and one singel code is interpeted.
So far, I hope any of you glorious coders might help me.
Thanks al lot
Joachim
igorPlug-USB double Event on key hold
Re: igorPlug-USB double Event on key hold
I have the same issue except I am using the USB-UIRT and a Harmony Remote (spitting out NEC codes for my Yamaha Receiver)...however when trying to hold down the volume buttons I get the USB_UIRT.Unknown.10 (also same with the original remote)...so I wonder if there is a way tell eventghost to ignore the Unknown.10
Sorry I am not trying to hijack your thread, but I am hoping maybe you found a solution.
