I figured out the answer to my previous post with some regedit fun but I now what a system and a Winamp Volume bar (Like the one you get with some of the keyboard/Soundcard/laptop/etc drivers
Does Event Ghost have an option for that? I already know I can get a simple OSD but is a Volume Bar OSD Possible?
Is a volume bar OSD possible?
Re: Is a volume bar OSD possible?
Yes some here helped me to create a volume bar for MPC that also has percentage after it. This shows how it works in MPC.
<EventGhost Version="1194">
<Macro Name="Volume Up" Expanded="True">
<Event Name="X10.Up" />
MediaPlayerClassic.VolumeUp()
EventGhost.PythonScript(u'from eg.WinApi.Dynamic import SendMessage\nTBM_GETPOS = 1024\nFind_MPC_Volume_Ctrl=eg.WindowMatcher(u\'mpc-hc.exe\', u\'{*}Media Player Classic{*}\', u\'MediaPlayerClassicW\', u\'\', u\'msctls_trackbar32\', 1, True, 0.0, 0)\nhwnd = Find_MPC_Volume_Ctrl()\n\nM = 2\n\nif len(hwnd) > 0:\n volume = int(SendMessage(hwnd[0], TBM_GETPOS, 0, 0)/5)\n eg.result = volume*M*u\'\\u2588\'\n volume2 = SendMessage(hwnd[0], TBM_GETPOS, 0, 0)\n eg.result2 = volume2\nelse:\n print "Window not found"\n eg.result = \'\'')
EventGhost.ShowOSD(u'Volume: {eg.result} {eg.result2}%', u'0;-48;0;0;0;400;0;0;0;238;3;2;1;49;Lucida Console', (255, 0, 0), (0, 0, 0), 0, (60, 150), 0, 2.0, False)
EventGhost.AutoRepeat(0.59999999999999998, 0.59999999999999998, 0.01, 2.0)
