Harmony One + Veris IR + EG = HELP!
quebert
Post by quebert »
I feel stupid here, I have a Harmony One I'm trying to get working with EG. I installed the latest EG, installed the Harmony software and set it up as MCE device. It's technically controlling my Windows 7, but I want to use EG to set up the advanced buttons and the touch screen ones (if that's possible) In EG I added the MCE remote plugin, checked the disable HID box and rebooted. When I load EG after rebooting and try to add a macro, I'm not seeing the remote code in the left panel. What am I doing wrong? This should be a simple process but it's really got me stumped. If I use the arrows on the Harmony One in EG they navigate the menus. Isn't disabling the HID supposed to stop this from happening?
What do I need to change to get this working? Also has anyone with a Harmony One gotten the main touch screen buttons (devices) to re-program. I'd like to have 3 and each one launch a different program on my PC. But in the Harmony software I can just set them up as MCE, so I'm thinking they'll all launch the same program? Thinking though maybe this can be changed in EG.
