How to use single button for Multitap.Enter and standard "enter" key?
When using Multitap to type Text in address bar after pressing "Multitap.enter" I would like the
normal Keyboard "enter" to be enable. Right know my setting has two enter buttons one for use with Multitap and one for address bar. which i do not like at all. Anyone know how to fix this issue?
Single buton for Multitap.Enter and standard "enter" key
Re: Single buton for Multitap.Enter and standard "enter" key
add an Emulate Keystrokes: {Return} after the Emulate Keystrokes: {eg.event.payload} resulting in you only having to press the Multitap enter to send the string and make a search directly.
But that's only if user want to web search directly to the address bar, for me i use address bar to search for my favorite and history and that's the only purpose of me going to the address bar. adding Emulate Keystrokes: {Return} will kill of the favorite and history search. I want the normal "enter" key to function so i don't have to click the "OK" button.
