Hi
Is there an action that will prompt the user on the computer to enter a value, or a yes or no answer to a question? I am trying to create an action that will sleep the computer if its not being used at a set time. If it is actively being used then the user should type in yes. if not the computer will go to sleep and stop wasting power.
The reason is I use the pc as an alarm clock and want it to shut down at 9 if I forget to turn it off manually. Im unsure if the inactive "goto sleep" will take into account music being played.
Darkflare
Re: dialog box prompt on host pc
One way could be to add the desktop remote plugin and use these macros (copy&paste to your configuration after adding desktop remote plugin):
<EventGhost Version="1397">
<Folder Name="Sleep-Timer" Expanded="True">
<Macro Name="Req" Expanded="True">
<Event Name="sleep-time-reached-event" />
DesktopRemote.CreateNew(100, 40, 10, 10, 20, (108, 108, 108), (255, 255, 255), (78, 78, 78), u'0;-13;0;0;0;700;0;0;0;0;3;2;1;34;Arial', u'Sleep-Timer', 0, True, True, True)
DesktopRemote.AddButton({'width': 210, 'event': u'', 'label': u'Shutdown?'})
DesktopRemote.StartNewLine(0)
DesktopRemote.AddButton({'backgroundColour': (176, 0, 0), 'event': u'yes', 'label': u'yes'})
DesktopRemote.AddButton({'event': u'no', 'label': u'no'})
DesktopRemote.Show(50, 50, True)
<Macro Name="Shutdown" Expanded="True">
<Event Name="DesktopRemote.yes" />
<Action Name="Shutdown">
EventGhost.Comment()
DesktopRemote.Close()
<Macro Name="Don't Shutdown" Expanded="True">
<Event Name="DesktopRemote.no" />
<Action Name="Don't Shutdown">
