Hi there
Is there any way that i can use event ghost to convert a code for pronto to output through the tellstick??
Thanks in advance
Edd
Pronto to tellstick
Re: Pronto to tellstick
No, you can't do a conversion,,,,but you can map events coming from a remote (like an IR remote) sending pronto codes.
You can put these pronto events in macros that in turn will activate commands sent by Tellstick
You would need
- a remote sending the pronto codes
- a receiver supported by EG like the USB-UIRT
- the Tellstick
You would need
- the Tellstick
I think I understand better what you would like to achieve. You have pronto codes for an rf device. I did send pronto codes myself earlier using a IR/RF converter (a standard pyramid/remote control extender worked out fine for this purpose)
I used a USB-UIRT that sends out pronto codes from EG to a IR-RF pyramid. Thats it
Thanks for the replies and yes I have the pronto codes for operating a device and a tellstick, I also have a usb uirt device. I just need to send the code out from my pc to a home easy device but this is not one that can learn the remote code (the he105) all the codes are set and i have them all in pronto format if anyone needs them.
Thanks in advance
Edd
Thanks in advance
Edd
