Wondering if anybody have done there own iphone app for eventghost?
I know there is Eventphone but i wont do my own custom made.
Iphone/Ipad app, making my own
Re: Iphone/Ipad app, making my own
Hi hans,
I wouldn't say I have made my own iPhone App for/with EG...
but I have used this one and customized the layout/pages/macros etc to suit my needs.
iPhone optimized web remote control for Webserver plugin
viewtopic.php?f=2&t=996&start=15&hilit=iphone
eventghost.net
Be there or be square.
hanspettersson
Thats a webbapp, I wont to do my own native app for eg.zian wrote:Hi hans,
Well, then you need to get the iPhone SDK. As long as you develop you can use the emulator, to try it out on a real iPhone/iPod you need a developer license. The cheaper license allows to put it into the app store and then it can be downloaded. If you have a jailbroken iDevice that might be different, but I am not too sure as I also started reading about that topic.
Read this first: http://en.wikipedia.org/wiki/IOS_SDK
Good luck!
Good luck!
