MODBUS TCP-IP
bastien
MODBUS TCP-IP
Post by bastien »
HELLO,
I want to know if some work or devellop a MODBUS-TCPIP plugin, to read or whrite some data on different hardware like API SHNEIDER or other ?
Thank you all,
PsI
Re: MODBUS TCP-IP
Post by PsI »
This would be an awesome plugin, modbus rtu/tcp is the most common fieldbus in the automation industry! I have always wanted to use EventGhost to control some of my modbusTCP devices, I've seen modbus libraries written in python online can anyone integrate them into EG? Unfortunately I have no experience with EG plugins or python for that matter :(
http://code.google.com/p/pymodbus/
http://code.google.com/p/modbus-tk/
-P
Re: MODBUS TCP-IP
MODBUS is for sure very interesting as such. Most of the people are however not so lucky to own devices and you need to find someone who has
- interest in MODBUS device integration in EG
- owns MODBUS devices
- can write a plugin in python for this
This will be very difficult as you have seen, no answers yet.
An idea would be to find an OPC Data Access Server for MODBUS. Matrikon is an example of a company that has this.
http://matrikonopc.com/opc-drivers/opc- ... tails.aspx
There has been some work here in this forum on OPC and I have a private plugin for EG that is acting as an OPC Client.
If you decide to follow this path I can upload my OPC Client plugin for you to test.
PsI
Re: MODBUS TCP-IP
Post by PsI »
Hi krambriw,
An OPC client would be cool!!! I would definately be interested in a copy of that :D
-PsI
Re: MODBUS TCP-IP
You can try to download an OPC Server for MODBUS here (free evaluation):
http://www.ingeardrivers.com/modbus_opc ... server.htm
Then try my OPC Client plugin and see if it connects, first
unzip into the folder plugins
OPC.zip
(18.88 KiB) Downloaded 217 times
