Change action each press
srodda
Post by srodda »
I am not sure if this is possible, however, I have a USB volume knob that emulates the keyboard press + or - depending on the rotation. However I would like to change it so that each time it is rotated instead of pressing plus I would like it to emulate shift+ctrl+1, then as its rotated more then emulates shift+ctrl+2, up until shift+ctrl+8 then goes back to shift+ctrl+1. Or if rotated anti clockwise it would do it in reverse. Maybe a counter could be used to do this with a variable action however I'm not sure how to do this. Any help would be much appreciated. Thank you
maurilloh
Re: Change action each press
Post by maurilloh »
Maybe you can use "enable an item" and "disable an item" to reach your goal.
you can make 8 folder in which you can insert the event, the keyboard emulate shift+ctrl+*, and then disable the folder and enable the follow and so on. When you reach the last folder it enable the first and disable the others. Other 8 folder for the anti clockwise.
I'm sure it can be done smartly but this could be a solution.
Bye.
Better yet, I think the action Exclusive enable a folder/macro,
or you can use Multitap plugin with "Single key" mode to generate several different events.
