Anti-Repeat
offbyone
Anti-Repeat
Post by offbyone »
Hi. First I wanted to say: Great work you did! Keep it up ;)
I have a little problem with my remote. The time before a event is repeated when a button is pushed seems to be 0. For example, when I push the PLAY/PAUSE button it sends the the event mostly twice (sometimes three times or if I`m fast only once). This means I need some way of telling my command/Makro? not to repeat for a certain amount of time. (0,2 seconds or so, so I have enough time to get my finger off the remote :lol: ).
Maybe this is already possible, but I haven't found it?
Bartman
Post by Bartman »
What remote do you use?
Are you getting multiple distinct events instead of one long enduring event?
