How to get a list of registered plugins/actions/macros
Is there a nice way to get a list of registered plugins with its actions, to get a list defined macros, using some python statements?
Elements that you normally see in your configuration tree.
Bets regards, Walter
Re: How to get a list of registered plugins/actions/macros
This seems to list added plugins:
eg.plugins.__dict__.keys()
This shows all actions from my XBMC2 plugin (the name might be different on other configs):
eg.plugins.XBMC.__dict__["actions"].keys()
Example Python script code that prints all plugin and XBMC2 actions to the log (useless):
<EventGhost Version="1544">
        EventGhost.PythonScript(u'print "Plugins:"\nfor Plugin in eg.plugins.__dict__.keys():\n    print Plugin\nprint "Actions for XBMC:"\nfor Actions in eg.plugins.XBMC.__dict__["actions"].keys():\n    print Actions\n\n')
Hope this is useful, I used the Python shell in the help menu to find the info.
Thanks Jonib, it works. I am able to find all installed plugins and their actions.
Do you happen to know where in eg name space I can find all defined macros? I have been trying to look there but there are no find functions in the python shell....
Dear Walter!
krambriw wrote:Is there a nice way to get a list of registered plugins with its actions ...
You can see how it's done in the plugin Websocket Suite.
krambriw wrote:... to get a list defined macros, using some python statements?
You have to recursively search through this list: eg.document.__dict__['root'].childs
Dear Pako,
I worked perfect, thanks a lot !!!
My very best regards, Walter
