I'm just getting started with EventGhost and would like to add a popup menu that lists a few applications that I can select and start. I've figured out how to create the menu, however, I would like to launch a macro for each item in my list. On the OS Menu: Show menu configuration popup I see the "Front and Back of Event String" boxes but I don't know if I can put a macro name in there or if there's more to it.
If I can only put an event in there is there a way that I can create an event to launch a macro?
OSM (On Screen Menu) - Basic Question
Re: OSM (On Screen Menu) - Basic Question
Unfortunately I do not understand your question.
Could you please describe in other words?
Unfortunately I do not speak English. Please use short, clear sentences.
