I am using EventGhost 0.4.1.r1582. It appears that emulated keystrokes are not going to the window found by Find Window, but rather to the window that has focus. This defeats the purpose of Find Window.
My configuration is:
MCE Remote plugin
Up
MceRemote.Mce.Up
Find Window: NextPVR.exe
Emulate Keystrokes: {Up}
Autorepeat current macro: 0.8
Find Window appears to be broken
Re: Find Window appears to be broken
I solved my problem. I switched from AlternateMceIrService to the regular Mce Remote, and did not switch the event from MceRemote.Mce.up to MceRemote.Up.
themaster1
find window work rather well if and only if (in my experience) the window has a window class and window name, program only is not enough
example for dvbviewer:
program: dvbviewer.exe
window name: DVB Viewer
window class: TfrmMain
example for xbmc:
program: XBMC.exe
class: XBMC
TMT5:
uTotalMediaTheatre5.exe
TotalMedia Theatre 5
_MIRACLE_20090309_1
There are exceptions aswell:
VLC:
Vlc.exe (that's it !)
If you use find window (with name & class) + bring to front that should solve your problem i believe
example for xbmc:
program: XBMC.exe
class: XBMC
TMT5:
_MIRACLE_20090309_1
VLC:
