webserver creates events but E.G. doesn't act on them
spyderespirt0
Post by spyderespirt0 »
I'm using the webserver plugin to go through a code and once its finally entered right it displays door unlocked/locked. Problem is this code only works intermittently, the event will show up in eventghost but eventghost does nothing at all.
<EventGhost Version="1582" Guid="{B7030A5C-F97C-400C-85D4-E9889228B984}" Time="1350588457.72">
    <Autostart Name="Autostart" Expanded="True">
        <Plugin Identifier="DesktopRemote" Guid="{5DFFBD61-7582-4D6F-8EA9-9CB36284C9CF}" File="DesktopRemote">
            gAIpLg==
        </Plugin>
        <Plugin Identifier="Webserver" Guid="{E4305D8E-A3D3-4672-B06E-4EA1F0F6C673}" File="Webserver">
            gAIoWAQAAABIVFRQcQBLUFguAAAAQzpcVXNlcnNcbmV0Ym9va1xEZXNrdG9wXG5ldyBleHBlcmltZW50YWwgaHRtbHEBWAoAAABFdmVudEdob3N0cQJYDQAAAHNweWRlcmVzcGlydDBxA1gHAAAANjU5Njc0MnEEdHEFLg==
        </Plugin>
    </Autostart>
    <Folder Name="door lock/unlock toggle" Expanded="True">
        <Macro Name="Show OSD: DOOR UNLOCKED" id="8" Enabled="False">
            <Event Name="Main.doorunlock/lock" />
                EventGhost.ShowOSD(u'DOOR UNLOCKED', u'0;-24;0;0;0;700;0;0;0;1;0;0;2;32;Arial', (255, 255, 255), (0, 0, 0), 5, (0, 0), 0, 3.0, False)
                EventGhost.EnableExclusive(XmlIdLink(13))
            <Action Name="write to arduino servo unlock door">
                EventGhost.Comment()
        <Macro Name="Show OSD: DOOR LOCKED" id="13" Expanded="True">
                EventGhost.ShowOSD(u'DOOR LOCKED', u'0;-24;0;0;0;700;0;0;0;1;0;0;2;32;Arial', (255, 255, 255), (0, 0, 0), 5, (0, 0), 0, 3.0, False)
                EventGhost.EnableExclusive(XmlIdLink(8))
            <Action Name="write to arduino door lock">
        <Folder Name="code attempt1" Expanded="True">
            <Folder Name="code" Expanded="True">
                <Macro Name='Enable: Trigger event "doorunlock"' id="20">
                    <Event Name="DesktopRemote.1" />
                        EventGhost.EnableExclusive(XmlIdLink(25))
                        EventGhost.DisableItem(XmlIdLink(43))
                        EventGhost.EnableItem(XmlIdLink(57))
                <Macro Name='Enable: Trigger event "doorunlock"' id="25" Enabled="False">
                    <Event Name="DesktopRemote.2" />
                        EventGhost.EnableExclusive(XmlIdLink(30))
                        EventGhost.DisableItem(XmlIdLink(57))
                        EventGhost.EnableItem(XmlIdLink(73))
                <Macro Name='Enable: Trigger event "doorunlock"' id="30" Enabled="False">
                    <Event Name="DesktopRemote.8" />
                        EventGhost.EnableExclusive(XmlIdLink(35))
                        EventGhost.DisableItem(XmlIdLink(73))
                        EventGhost.EnableItem(XmlIdLink(89))
                <Macro Name='Enable: Trigger event "doorunlock"' id="35" Enabled="False">
                    <Event Name="DesktopRemote.4" />
                        EventGhost.ShowOSD(u'CODE CORRECT', u'0;-24;0;0;0;700;0;0;0;1;0;0;2;32;Arial', (5, 216, 37), (0, 0, 0), 5, (0, 0), 0, 3.0, False)
                        EventGhost.TriggerEvent(u'doorunlock/lock', 0.0)
                        EventGhost.EnableExclusive(XmlIdLink(20))
                        EventGhost.DisableItem(XmlIdLink(89))
                        EventGhost.EnableItem(XmlIdLink(43))
            <Folder Name="restart code entry if these#" Expanded="True">
                <Macro Name="<unnamed macro>" id="43">
                    <Event Name="DesktopRemote.3" />
                    <Event Name="DesktopRemote.5" />
                    <Event Name="DesktopRemote.6" />
                    <Event Name="DesktopRemote.7" />
                    <Event Name="DesktopRemote.9" />
                    <Event Name="DesktopRemote.0" />
                        EventGhost.EnableItem(XmlIdLink(20))
                        EventGhost.DisableItem(XmlIdLink(35))
                        EventGhost.DisableItem(XmlIdLink(30))
                        EventGhost.DisableItem(XmlIdLink(25))
                <Macro Name="<unnamed macro>" id="57" Enabled="False">
                <Macro Name="<unnamed macro>" id="73" Enabled="False">
                <Macro Name="<unnamed macro>" id="89" Enabled="False">
    <Folder Name="desktop remote">
        <Macro Name="Desktop Remote: Create New Remote" Expanded="True">
                DesktopRemote.CreateNew(85, 85, 20, 20, 4, (108, 108, 108), (255, 255, 255), (78, 78, 78), u'0;-19;0;0;0;700;0;0;0;255;1;2;1;49;Terminal', u'keypad', 0, True, True, True)
        <Macro Name="<unnamed macro>" />
        <Macro Name="Desktop Remote: Add Button: 3" Expanded="True">
                DesktopRemote.AddButton({'event': u'1', 'label': u'1'})
        <Macro Name="Desktop Remote: Show at 0,0">
                DesktopRemote.Show(0, 0, False)
        <Macro Name="Desktop Remote: Start New Line" Expanded="True">
                DesktopRemote.StartNewLine(20)
spyderespirt0
Re: webserver creates events but E.G. doesn't act on them
also can anybody help me figure out why the code attempt 1 folder disables after the successful code entry?
