Google TV
palms13
Google TV
Post by palms13 »
Hello I just discovered EventGhost and had a couple of question. Number one is has anyone ever used EventGhost to send commands from a GoogleTv device to a Windows Media Center Computer? For those of you unfamiliar with GoogleTv, it sends commands via IR to my cable box. Now I would like to get rid of the cable box and have the GoogleTv send the commands to my htpc with windows7. For instance when I find something to watch in the GoogleTv guide I press enter and it sends the command to the cable box to tune to the correct channel. Am I understanding EventGhost correctly that this is possible? Thanks in advance for any insight.
Palms
