RemoteGhost v1.4.3 - Windows Phone Remote App for EventGhost
Rvmax
Post by Rvmax »
RemoteGhost
RemoteGhost will turn your Windows Phone into EventGhost remote, one of the most powerfull tools for home automation and homecinema PC. Remote Ghost send event to EventGhost server on your computer in order to control your favorite applications or home cinema equipment.
EventGhost can control Windows operating system, many programs like XBMC, PowerDVD  and homecinema equipment like Samsung TV, Denon AV  and can be customized to control all types of Windows applications.
RemoteGhost is not a standalone remote application. EventGhost Server is require.
Main features
- Send events to EventGhost server
- Send event with button & Windows Phone keyboard
- Send Wake on LAN on startup
- Advises user to enable Wi-Fi
- FF, Rewind, Up, Down, Left and Right are repeat button you can hold the button to spam the command
Install & Configuration
On Computer
Be sure to have a computer with EventGhost Installed
Start EventGhost and click Add PlugIn....
Select Network Event Receiver
In the plugin configuration setup the TCP/IP Port (Default 1024)
Password to use for security
And the Event Prefix to TCP
Click OK
On Windows Phone
Install the application from Windows Phone Store
Use the configuration button to setup your EventGhost Server
Use it and check eventghost server New Event are here !!!
More info and screenshots on xda : http://forum.xda-developers.com/showthr ... ?t=2076716
Rvmax
Re: RemoteGhost - Windows Phone Remote App for EventGhost
Post by Rvmax »
Application is available on windows phone store for free.
qr
qr
Download on Windows Phone Store
Rvmax
Re: RemoteGhost v1.3.0 - Windows Phone Remote App for EventG
Post by Rvmax »
Update 1.4.0
  • Add appbar with settings, info and keyboard link
  • Inform user to go to settings if no eventghost server is setup
  • Little modifications in remote design
RemoteGhost 1.4 Pro is also available on marketplace with full remote creation and customization.
zian
Re: RemoteGhost v1.4.0 - Windows Phone Remote App for EventG
Post by zian »
Rvmax wrote:RemoteGhost
Main features
On Computer
Click OK
On Windows Phone
SWEET,
Very cool Rvmax.
One question...
What is Windows Phone?
:P
eventghost.net
Be there or be square.
Rvmax
Post by Rvmax »
Oh oh Eventghost is a pure Windows project, you've probably heard of Windows Phone.
try it :)
Rvmax
Post by Rvmax »
Update 1.4.2
  • Add compatibility with dark / light phone theme
  • When keyboard is open, click on keyboard icon in application bar will hide it.
  • Hide system tray (clock, etcÔǪ.) on black screen
  • Improve communication with EventGhost server.
  • Fix Wake On Lan feature
Rvmax
Re: RemoteGhost v1.4.2 - Windows Phone Remote App for EventG
Post by Rvmax »
Update 1.4.3
  • Optimize application for Windows Phone 8
