Cannot load configuration
GoldenEye
Post by GoldenEye »
Hi, I am using the latest EG release.
My goal is to send a broadcast event to eventghost which should power off my mediacenter.
The attached configuration works well but after a reboot, EG cannot load ANY configuration anymore - I need to reinstall EG.
EG shows the following log:
Traceback (most recent call last) (1600):
File "C:\Program Files\EventGhost\eg\Classes\MainFrame\__init__.py", line 345, in FuncWrapper
func()
File "C:\Program Files\EventGhost\eg\Classes\MainFrame\__init__.py", line 828, in OnCmdOpen
self.document.Open()
File "C:\Program Files\EventGhost\eg\Classes\Document.py", line 353, in Open
self.StartSession(filePath)
File "C:\Program Files\EventGhost\eg\Classes\Document.py", line 157, in StartSession
eg.eventThread.Func(eg.eventThread.StopSession)()
File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 62, in __call__
File "C:\Program Files\EventGhost\eg\Classes\EventThread.py", line 151, in StopSession
actionThread.Func(actionThread.StopSession, 120)()
File "C:\Program Files\EventGhost\eg\Classes\ActionThread.py", line 76, in StopSession
eg.document.autostartMacro.UnloadPlugins()
AttributeError: 'Document' object has no attribute 'autostartMacro'
Thx for any help.
G.
Mediencenter_.xml
(667 Bytes) Downloaded 126 times
kkl
Re: Cannot load configuration
Post by kkl »
You might try looking at the thread that was just recently posted, Error Loading Config.
