EventGhost and iRule, not working.
MANswers
Post by MANswers »
Hi all,
I am trying a very simple function from the iRule app using eventghost, as seen in this youtube video.
http://www.youtube.com/watch?v=Azjp9CxyfCw
Just simple two buttons test1 and test2. I have insatlled eventghost, and created the broadcaster plugin with port 33333 and also added the ip address ending with 255 in my irule gateway in the iphone app.
Device has been added as network to the gateway in irule in iphone with the ip address 10.1.10.255 (the listening computer where eventghost has been installed).
In the irule app when i click the two buttons i created and assinged the udp network code as seen in the video above, i do see its transmitting as the icon is green color not red.
But i dont see that in the eventghost log. It should show udp test1 and udp test2 in the log in the eventghost window, but it does not.
I also did made sure that the windows firewall and the 3rd party firewall is turned off, also portforwarded ip address and the port both. But no help. What am i doing wrong, is there something in this video that has been missed. I am totally new to eventghost (but not to irule).
MANswers
Re: EventGhost and iRule, not working.
Post by MANswers »
is there a great eventghost installation tutorial? I would like to do a lot of stuff with eventghost, but i am not even able to get it started.. not even basic commands work. DO i need to install add's as well with this to make it work.
forget irule. i was able to use mce controller and make use of irule. all i want right now is to make eventghost work properly. by the way mce controller with 5150 and 10.1.10.15 ip add works fine. dont know why eventghost does not show anything.
johnsills1
Post by johnsills1 »
Did you ever figure this out?
mickelin
Post by mickelin »
I made that video and a few others on iRule/EventGhost integration. Works flawlessly. Let me know what issues you have and I'll help you sort it out.
