Hi all,
Im searching something to take control of a web player build in silverlight, using a simple Microsoft remote control.
To sum up, i watch some movies on my provider web site, and the player is made with silverlight.
I would like to change channel, use volume control with my mce remonte.
The web site adress :
http://www.canalsat.fr/decouvrir-live-t ... ve-tv.html
So, my question is : do you know if eventghost can help me to control this player.
For information, keyboard shortcut doesnt work....
Thanks a lot
remote control of silverlight player
themaster1
Re: remote control of silverlight player
Forget using the web player use xbmc instead, much better user experience imo
it has the canalsat plugin
Hi themaster1.
Thanks for your answer.
I have search this addon but i have not find it.
With this one can you log into your web account to see live and on demand tv?
If you have a link it Will be great.
Xbmc is runing on my htpc
Thanks a lot
Eric
Thanks a lot
Eric
themaster1
Pour les chaines payantes je sais pas sinon le plugin canal+ tu peux le trouver ici:
http://passion-xbmc.org/addons/
il faut cr├®er un compte d'abord il me semble pour voir les plugins
Si tu es abonn├® ├á la tv par adsl (free, orange) il existe un autre plugin (son nom m'├®chappe) renseigne toi sur le forum de xbmc passion
