I have EG and XBMC on my windows PC and i use Yatse remote on my android smartphone to control XBMC.
With Yatse; i can send a wol signal to my windows PC.., i don't need that cause my pc is always awake, but i would like to use this packet to start XBMC.
How can i do it ?
I tried with the plugin "broadcast" which can receive udp packet but i don't see anything when i send wol.
I tried eventghost android.It works fine and i can start XBMC from a layout but i would like to do the same action from Yatse..
Or maybe you have a better suggestion ?
Thanks for your help: )
Event on EG windows when Yatse Android send Wol ?
Re: Event on EG windows when Yatse Android send Wol ?
Thansk of this link, it's a good solution but if i could use eventghost, i could avoid to install another application.
Is broadcaster plugin the good way to listen wol magic packet ?
I use it and i changed udp port to 9.It seems to received something but i have an error message:
error: uncaptured python exception, closing channel <eg.CorePluginModule.Broadcaster.Server connected 192.168.1.2:9 at 0x3590c60> (<type 'exceptions.UnicodeDecodeError'>:'ascii' codec can't decode byte 0xff in position 0: ordinal not in range(128) [asyncore.pyc|read|76] [asyncore.pyc|handle_read_event|414] [C:\Program Files\EventGhost\plugins\Broadcaster\__init__.py|handle_read|95] [C:\Program Files\EventGhost\eg\Classes\PluginBase.py|TriggerEvent|133] [C:\Program Files\EventGhost\eg\Classes\EventThread.py|TriggerEvent|78] [C:\Program Files\EventGhost\eg\Classes\EventGhostEvent.py|__init__|84])Re: Event on EG windows when Yatse Android send Wol ?
So i installed xbmc starter, but i'm always searching a way to do the same job with eventghost.
I'm waiting for help.
I have the same requirement, and the Broadcaster plugin works well for me. I am using Eventghost 0.4.1.r1640 and Yatse 3.9.1.
Broadcaster is listening on UDP port 7 (default for WoL). When Yatse sends the WoL packet to that port, Eventghost receives a Broadcast.YatseStart-Xbmc event.
Try updating to the latest Eventghost and Yatse versions, maybe this will solve your problem.
thanks for your f├®es back.
I use "xbmcstarter" bescause i never getted eg broadcaster working, but in the next week, i will upgrade my os from xp to seven, and i will try again with eg.
Did you use seven ?
Did you use seven ?
It works! But i had to change defaut yatse port from 9 to 7 cause broadcater doesn't seems to work with port 9...
