Save eventghost xml after event
spyderespirt0
I'm using the serial plug in to control an outside object, and after its done it toggles the macro to disabled and enables another macro. I want to be able to save the eventghost xml file after it disables the macro, so when and if it restarts it will be the same state. Is there a python command for this?
Re: Save eventghost xml after event
I think that EventGhost Application Control Plugin might do what you want.
spyderespirt0
++10 to you sir! exactly what I was looking for!
