any Sharp Aquos LCD plugin around?
jang430
Post by jang430 »
Thanks in advance
kalia
Re: any Sharp Aquos LCD plugin around?
Post by kalia »
Try this. My first plugin! :D
Let me know if it works.
kalia
Sharp Aquos TV Serial Plugin
(8.46 KiB) Downloaded 229 times
jang430
Post by jang430 »
Thanks! I'll reply as soon as I get to test it.
jang430
Post by jang430 »
Hello Kalia,
Works perfectly :-) Thank you very much.
leothlon
Post by leothlon »
Hi.
How does this plugin work? over serial port or throu lan?
jang430
Post by jang430 »
Hello Kalia,
I just noticed that the plugin works when the PC is turned on, or has been recently turned off (you can still control it within 5 seconds from turning off). Once it's been off for a while, you can't turn it back on. You'll have to do it manually via remote, then, you can once again control it via serial plugin.
jang430
Post by jang430 »
leothlon wrote:Hi.
I use serial cable since my TV doesn't support lan yet.
kalia
Post by kalia »
jang430 wrote:Hello Kalia,
I will look into it when I get a chance but I am pretty sure it has something to do with the TV serial port going to sleep (low power mode).
kalia
jang430
Post by jang430 »
Hello Kalia, I thought the same as well. Though how do you address that? Is there. Setting in the tv to change that?
kalia
Post by kalia »
jang430 wrote:Hello Kalia, I thought the same as well. Though how do you address that? Is there. Setting in the tv to change that?
I could not find a setting but what I can suggest is sending the "Power On" command twice (assuming you are trying to turn TV on after the PC starts up again).
Also, if that does not work, try sending the command:
RSPW1
before shutting down the PC (only once - not every time you shut down). Then try sending the "Power On" command twice after startup.
Let us know what works for you!
Kalia
jang430
Post by jang430 »
Thanks Kalia. Will give feedback once I get to try it.
hanspettersson
Post by hanspettersson »
The Plugin works great. Thanks
Sending commands works great.
But i can┬┤t get any feedback from my TV?
I have try Power status and Volume.
eastonenn
Post by eastonenn »
Hi !
I think i have the same issue as hanspetersson in the comment above.
Ive tried to setup this plugin.
In EG everything works fine I find the plugin and i can choose my COM-port in the plugin-setup and i can send the commands.
Then to the problem, i dont get any response from the TV and for example if i send a Volume command the TV dont react to it either.
I have a USB-serial cable. and im running windows 8.1
anyone got any tips ?
kalia
Post by kalia »
hanspettersson wrote:The Plugin works great. Thanks
Thanks hanspettersson for the feedback. I don't use this plugin anymore, but this is what I can suggest:
Try this action after the Volume and Power Status actions:
<EventGhost Version="1669">
        EventGhost.PythonCommand(u'print eg.result')
Print Volume Result
Print Volume Result
kalia
Post by kalia »
eastonenn wrote:Hi !
eastonenn,
Do you get any errors when adding the plugin?
kalia
