Hi all,
First let me say that eventghost ROCKS! I've been messing around with an htpc since 1998, and I wish I had found this software a long time ago.
That being said, I have a small problem with powerdvd 7.3
I have the event/task swticher plugin installed, and it's working fine, except when I minimize powerdvd, and then switch back to it, no events are created. So the wrong context config (default) is used instead of the correct one I created.
I have a seperate macro for switch to powerdvd and in it I have the events for when powerdvd is first started, but after that nothing else seems to be added to the event window.
Has anyone seen behavior like this before?
Thanks in advance for any help.
- Cguy
P.S. Once I get all setup and working, I'll upload my various configs here. Seems like that's all thats needed for this to be the best remote software ever, a list of downloadable configs.
