Hi.
Have any one made a pluginfor openhab http://www.openhab.org/index.html?
Would be great to integrate eventghost and openhab.
Openhab
Re: Openhab
You can use the MQTT binding available in openHAB...and the MQTT Client plugin in EvenGhost and you should be good on the way
