Lost my Eventghost Configuration(SOLVED)
medelay
Post by medelay »
Hey Guys,
Im using 0.4.1r1640 on a windows 7 laptop that is always on.
And a few hours ago i noticed that my eventghost was blank, as is filled with the standard stuff you start with (the examples). I never had this happen before so i searched goolge and the forums here but could not find any more information.
Since this is a configuration that i have been working on for almost 2 years it is of great value to me.
I checked the map from were i start my eventghost but there isnt any .xml file in there. i checked the C:/user/user/AppData map nothing there either?
I did use EGApControl to auto save my configuration before evry restart of the system. And i also installed eventghost on another laptop in the same network but this shouldnt really be the problem? I can not remember if i ever choose a custom path to save it in since it has been 2 years ago.
Any help would greatly be appreciated
medelay
Re: Lost my Eventghost Configuration
Post by medelay »
I solved it. I think it did have something to do with the EGAppControl, i think eventghost somehow loaded the example instead of my standard configuration and on lockdown EGAppControl saved the example over my normal configuration, how this happend i dont know it is just speculation.
I solved by going to my C/user/user/Appdata and right clicking on the evenghost map, than right click it go to previous versions. I than reset it to yesterday. Closed eventghost restarted it and it worked like a charm again.
