Problem with Plugin for Streamzap PC remote
jbo12
Post by jbo12 »
Each time I try to add this plugin I get error message:
PluginTools._Exception: 'Cannot open Streamzap driver!\nPlease check that the receiver is connected properly and no other application is accessing the driver.'
I reinstalled the Streamzap drivers (3.0.0) from the Streamzap website
I am running XP SP2. I checked hardware device manager and everything seems to be ok with the drivers. I am able to use the Streamzap remote to control media programs without error and able to use the macro buttons on the remote to launch MM3 and Zoomplayer without problems.
I installed EventGhost 0.3.5c build 908 downloaded from SourceForge
Any ideas why EventGhost is not accepting this plugin?
jbo12
Re: Problem with Plugin for Streamzap PC remote
Post by jbo12 »
Found the answer. Disabling the Streamzap remote program that loads at Windows startup fixed it.
