EG freezes with specific keystorke emulation
temm
Post by temm »
I've setup eventghost on a newly installed windows 8.1 64bit intel nuc pc using the Generic HID plugin. I have a logitech harmony ultimate remote and almost everything works fine. I have installed plex media player as my main plex client and i'm trying to add some custom functions.
For the most part these work fine, Start Application, emulate keystrokes {Alt+S}, {Alt+Shift+S}, etc, but for a specific keystroke L (change subtitle language) EG freezes showing "Not responding" in the task manager. I have assigned the "Green" button on the remote twice (for the alternative ir codes) to emulate key L. I have assigned the "Red" and "Yellow" buttons with {Alt+S} and {Alt+Shift+S} and work perfectly.
This behavior is either when I'm using Plex or if I quit Plex and I'm just looking at the desktop. It may work and show up in the EG log, but 2 out 3 it will crash.
Is there any log that i check to see what's causing the problem? Any other ideas?
Teo
