Thank you very much for creating this program. I hooked up my multimeter to my bd
remote and I can confirm that when your plugin puts the
remote to sleep the current drops from about 16 milliamps to 0.14 milliamps.
I am using Vista 32bit with the microsoft default stack. Eventghost 3.7.r1194 and I believe the latest
ps3 plugin from this thread.
2 comments about the program:
1 - small text correction for you: "... minutes to
whait before put to sleep" should be spelled "wait". Also I would phrase it like this: "minutes to wait before sleeping" or "minutes to wait before putting device to sleep"
2 - what is the meaning of the colours of the bluetooth icon in the notification area? At the moment my
remote is "sleeping" and the icon is green. The way I see it the colours should work as follows:
Green -
remote is on
Yellow -
remote is sleeping
Red - process is not running (not started, stopped, or error)
Oh one other thing, I have a bluetooth mouse and keyboard on the same stack. If I keep using my mouse or keyboard will it stop my
remote from going to sleep? I will try to test this myself.
edit: ok, the mouse and keyboard do not prevent the remote from going to sleep which is good, but when the remote is put to sleep, the mouse and keyboard are put to sleep as well. BAD! especially since my mouse and keyboard can take quite a while to wake up. Any idea how to fix this?
Problem: If I use my BD
remote to put my computer to sleep my
remote will remain on, correct? Is there a way to detect when the computer is about to sleep and put the
remote to sleep first?
Edit: ok, the remote seems to sleep when windows sleeps. If I press a button on my remote while the computer is sleeping the amperage goes up to 22 milliamps (higher than when operating) so I guess it is doing a broadcast looking for the computer, but anyway it gives up after about a minute and the amps go back down to almost 0.
thanks again, looks like soon I might be able to unsolder the ugly switch I had put on my
remote!
