Livin,
Did you do it like this...?
To upgrade, it is very important to follow the steps below in the specified order.
1) When EG is running current version, disable the
SunTracker plugin and all
SunTracker actions so that they all stops
2) Unzip or copy the content of the new zip file
3) Now configure the
SunTracker plugin, as example look at the picture below.
- enter your location id: A five digit US zip code or location ID. To find your location ID, browse or search for your city from the Yahoo! Weather home page(
http://weather.yahoo.com/) The weather ID is in the URL for the forecast page for that city. You can also get the location ID by entering your zip code on the home page. For example, if you search for Berlin in Germany on the Yahoo! Weather home page, the forecast page for that city is
http://weather.yahoo.com/germany/berlin/berlin-638242/. The location ID is 638242.
- select your units: type of units. 'metric' for metric or 'non-metric' (currently planned for future functions)
- select how often you want weather data updates (default is every 5 minutes)
When finished, click ok, then enable the plugin so that it starts.
4) Now for each action, configure each of them by opening them and clicking ok
5) Enable each of the actions
6) Open the settings for the plugin again and check that they are all running
7) You are done!
