MediaMonkey
Re: MediaMonkey
Yes, you found a bug.
I found him not, because I have all the filters in this setting:
Once the setting is different, the error occurs.
I hope, that the more bugs you do not find.
Your first post after the 0.2.4 version of scared me :) .
Version 0.2.5
(145.14 KiB) Downloaded 272 times
jitterjames
Re: MediaMonkey
Post by jitterjames »
sorry to scare you Pako! When I first tried it I had a lot more problems,very erratic behaviour, but I reinstalled both mediamonkey and eventghost and it seemed to help.
I'll try this one out today. thanks
jitterjames
Re: MediaMonkey
Pako :!: :!: :!:
You are my hero :D
So far it is FANTASTIC. Very fast. I had some major problems trying to configure macros from the old version, so I just deleted them and started over. I don't think it's worth worrying about, but you might need to make a note when including the new version of the plugin in the standard installation.
I will let you know if I find any bugs or text. I probably won't have time to look at the text for a few days though.
Thanks again. J
jitterjames
Re: MediaMonkey
I just installed Windows 7 x64, and cannot connect to mediamonkey at all now. Everything else seems to be ok with eventGhost and other plugins.
MediaMonkey: Start/Connect MediaMonkey
Exception in thread MediaMonkeyWorkerThread:
File "threading.pyc", line 525, in __bootstrap_inner
Error in Action: "MediaMonkey: Start/Connect MediaMonkey"
Traceback (most recent call last) (1194):
File "threading.pyc", line 477, in run
File "C:\Program Files (x86)\EventGhost\eg\Classes\ActionBase.py", line 168, in CallWrapper
File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 183, in __MainLoop
File "C:\Program Files (x86)\EventGhost\plugins\MediaMonkey\__init__.py", line 977, in __call__
File "C:\Program Files (x86)\EventGhost\plugins\MediaMonkey\__init__.py", line 916, in GetValue
File "C:\Program Files (x86)\EventGhost\plugins\MediaMonkey\__init__.py", line 209, in Finish
File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 147, in Start
File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 72, in __call__
File "C:\Program Files (x86)\EventGhost\plugins\MediaMonkey\__init__.py", line 201, in Setup
AttributeError: MM
File "win32com\client\__init__.pyc", line 95, in Dispatch
File "win32com\client\dynamic.pyc", line 104, in _GetGoodDispatchAndUserName
File "win32com\client\dynamic.pyc", line 84, in _GetGoodDispatch
com_error: (-2147221005, 'Invalid class string', None, None)
Re: MediaMonkey
Unfortunately I do not have available Seven/64.
I can try a Seven/32.
If this will occur there, I'll try to solve.
jitterjames
Re: MediaMonkey
OK... It works on win7 32 BETA, and vista x64. So it's weird that it does not work on win7x64.
If there is anything I can do to help let me know.
jitterjames
Re: MediaMonkey
just for fun, I ran eventGhost in compatibility mode (vista sp2) as administrator, but it made no difference. I also tried to disable UAC
this sucks.
jitterjames
Re: MediaMonkey
OK It is working now. I'm not exactly sure what make it work, but after I disabled UAC, it was still not working. Then I tried an older version of the plugin and it was not working either. I tried connecting with the old version of the plugin AFTER starting mediamonkey and it worked.
then I installed the new version of the plugin, started mediamonkey and tried to connect and it worked.
now everything is normal and I can connect/disconnect and mediamonkey doesn't have to be started first... (in other words everything is back to normal)
hope this helps someone...
Re: MediaMonkey
Thank you for the good news.
I'm afraid, that if problem was really just for the version Seven x64,
I could not do anything about it.
Re: MediaMonkey
I made a tiny improvement of actions Load Playlist by SQL query.
Prior to processing the contents of a text field is now called the function
eg.ParseString(). So you into this field, you can write even {eg.event.payload}.
Version 0.2.6
(145.23 KiB) Downloaded 273 times
derelict
Re: MediaMonkey
Post by derelict »
could you add the eg.parsestring function to load playlist by filter as well ?
Re: MediaMonkey
derelict wrote:could you add the eg.parsestring function to load playlist by filter as well ?
Of course. I'm just not previously thought, that this might also make sense. But now I see, that yes.
Version 0.2.7
(145.28 KiB) Downloaded 257 times
derelict
Re: MediaMonkey
Post by derelict »
awesome! Thanks!
Marcel
jitterjames
Re: MediaMonkey
Hi Pako I think I have a real bug to report. For a while I thought it was just in windows 7 but I recently went back to Vista (32bit) and I am having the same problem, so I can report this problem on multiple systems and multiple operating systems.
the problem is cause by the following:
1- connecting to mediamonkey with eventghost using your mm plugin
2- closing mediamonkey (it doesn't matter if I just close it directly (alt-f4) or use exit/disconnect command from the mm plugin).
3- open / reconnect mediamonkey with mm plugin
after this most things work fine. play, pause, next song, volume, get song info etc. all work.
but, load playlist by name, load playlist by filter and sql queries do not work for some reason.
currently solution: I must close and reopen EventGhost then reconnect to mediamonkey and everything is fine until I close mediamonkey again.
Pako, if you could please look into this when you have time (no rush I have been living with it for a while anyway).
If anyone has a chance to try to reproduce this error please let me know.
thanks, J
Re: MediaMonkey
Yes, it is a bug. I think that I managed to fix it. But I'm not entirely sure.
You can try the latest version (0.2.9) from the SVN repository.
