xPL
atz6975
Re: xPL plugin
Post by atz6975 »
:oops: indeed...
Do you want some feedback once Istart playing with SC7?
eg 0.3.7.1076
Vista, x32, SP1
damage
Re: xPL plugin
Post by damage »
if you'd like to, but don't count on any immediate enhancements. i don't really use EG much. my goal was to provide basic xPL functionality. anything beyond that, may take a while to implement as i've got 2 million other projects going on at the same time.
atz6975
Re: xPL plugin
Post by atz6975 »
Sure not problem.
Also, as far as interacting with SC7 I see more potential on CLI as xPL and EG tend to overlap rather than just enabling more.
Anyway thank you for your quick reply.
eg 0.3.7.1076
Vista, x32, SP1
damage
Re: xPL plugin
Post by damage »
if you don't have any other xPL running, then it doesn't make sense to use xPL just to control SC. but if you have other xPL apps, like my just released xPL Jabber gateway for example ( http://doghouselabs.blogspot.com/2009/0 ... _8418.html ), the xPL plugin will interface between that app & EG and allow IM control of stuff...
also, i found a bug in my EG plugin and updated it & the download link http://doghouselabs.blogspot.com/2009/0 ... _6074.html
atz6975
Re: xPL plugin
Post by atz6975 »
Yes, I see what you mean.
eg 0.3.7.1076
Vista, x32, SP1
Re: xPL plugin
okey, Blabber is running and connected to my gmail account (Google)
How can I send events from eg now???
Settings??? Please explain
BestR Walter
damage
Re: xPL plugin
Post by damage »
krambriw wrote:okey, Blabber is running and connected to my gmail account (Google)
BestR Walter
hopefully, you've already read about xPL here http://wiki.xplproject.org.uk/index.php/Main_Page, have an xPL hub installed and configured the xPL instances using xPL HAL or something similar. if you need xPL help to get up & running then go to the xPL forums http://www.xpl-home.org/forums/index.php
back to your question, all you need to do is create an xPL event that does what i wrote in my blog post http://doghouselabs.blogspot.com/2009/0 ... _8418.html
Just create a control.basic packet like this:
dest = doghouse-blabber.xyz
type = xpl-cmnd
control.basic
   [email protected]/gmail.some_resource_numbers
   current=somebody rang the doorbell
you do this by adding an eg action to send an xPL message and fill out the dialog boxes as described above, except filling in the xpl target field with your instance name for your blabber install, the device field with the contact you are wanting to IM with and the current field with your message.
Re: xPL plugin
OK, thanks,
I did try it with Vista, but when running xPL HAL, the eg plug-in did not work anymore :(
Should Vista be supported?
damage
Re: xPL plugin
Post by damage »
i can't see a reason why the plugin, if it was working, would stop when xPL HAL started. do you have an xPL hub running? you can also use DCM, available here http://www.xpl4java.org/xPL4Java , to configure instead of xPL HAL.
Re: xPL plugin
OK,
Yes, of course the hub as well, I did do exactly as it is described;
Installed
1. Hal
2. Hal update
3. Hub
In XP it works, in Vista it doesnt. The problem comes when u try to add the xPL plugin in EG
Below is the log from eg
Autostart
Stack trace (most recent call last) (851):
  File "C:\Program Files\EventGhost\eg\Classes\UndoHandler\NewPlugin.py", line 38, in Do
  File "C:\Program Files\EventGhost\eg\Classes\TreeItem.py", line 81, in Create
  File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 307, in CallWait
  File "C:\Program Files\EventGhost\eg\Classes\MainFrame\__init__.py", line 352, in FuncWrapper
    func()
  File "C:\Program Files\EventGhost\eg\Classes\MainFrame\__init__.py", line 830, in OnCmdAddPlugin
    ).switch(self.document, pluginInfo)
    file=pluginInfo.pluginName
    self = eg.actionThread.CallWait(partial(cls, parent, node))
  File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 309, in CallWait
    "Timeout in %s.CallWait()" % self.__class__.__name__
Exception: Timeout in ActionThread.CallWait()
damage
Re: xPL plugin
Post by damage »
i assume the plugin worked before you installed xPL HAL since you wrote this previously:
then, like i said before, use DCM to configure instead. (and if it worked before you installed xPL HAL then it would probably be a good idea to uninstall it). i don't have vista so i can't test things out on it.
damage
Re: xPL plugin
Post by damage »
i posted a sample python script on my blog that parses an incoming xPL message & sends an xPL response back
http://doghouselabs.blogspot.com/2009/0 ... r_982.html
Re: xPL plugin
@damage
Thanks for your kind help! I have finally made it, it works on my Vista as well.
(Remember that you have to create two accounts for Google Talk if you want to IM to your own running EG)
I don't know why I had problems but I had to do it in the following way:
1) stop the service xPLHub
2) start EG and add the xPL plugin, create the macro, action and paste in your script according to your guide
Now EG starts OK
3) start the service xPLHub
4) configure the config.txt with the "EG google talk" account settings and start Blabber
5) configure xPL devices (I used the DCM)
6) logon to Google Talk from another computer using your "normal google talk" account
7) add the "EG google talk" account to your contacts
eight) send "test" and the answer shall be "EG got your test"
Once everything worked, I could start EG again in any order without problems.
The problem is when you add the xPL plugin to the configuration. Works ok with XP but not with Vista
damage
Re: xPL plugin
Post by damage »
good to hear you got things working. one thing, the xPL hub needs to be running before any other xPL app starts - so it should have been running before you added the xPL plugin to eg. ( see http://wiki.xplproject.org.uk/index.php ... ws_xPL_Hub )
now the fun begins :)
Re: xPL plugin
Hi, yes but that was exactly what caused the problem...if I instead had the hub stopped and configured EG with the plugin in this mode, and saved and restarted EG once the hub was running again, everything worked
