Actually, I have an MX Airmouse and that is what I do. I thought there was a hotkey to open the "select from folder" dialog, and I wanted to use that, then the up/down/left/right buttons to select a move, then "select source" to close the window and start the movie. But I couldn't get the dialog to open. So it is pretty much useless. Did you have a better way in mind for your plugin? I'm all ears if there's a way to get it to work.scorpie wrote:haven't found another solution.
but i still have a question. If u use the "select source" function and u select media file - how do u navigate with the remote thru the new window? Do u use the mouse then *lol* wouldn't be very practical.
My long term plan was to create a different plugin/program for selecting a movie, then passing the location to TMT.
Brett
