Monitor log file for error
ijourneaux
Re: Monitor log file for error
Post by ijourneaux »
First. I really appreicate the assistance. You have already done more that I expected. I would love to help improve it.
I haev attached a copy of the logwatcher Version 1, the test log file I am using and the results of the log
Version one seems to execute everytime I make a change to the log file. THe portion of the log file I covers me adding "test to the log file 3 times. In each case, the script executed but it detected and triggered the error message script all three times when it should not have triggered it at all.
This seem to closest to working they way I would need it to. The problem, as you pointed out in an earlier email, was how to keep track of what has been read and what hasn't.
8:42:32 AM File.BTVerror [u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test']
8:42:32 AM Python Script
8:42:32 AM BTV.error_occured u"Adding error: '12'"
8:42:32 AM Transmit IR
8:42:32 AM Transmit IR off
8:42:32 AM Timer: Start new or control running timer
8:42:42 AM Timer.BTVon (0, '4/17/2010 8:42:42 AM')
8:42:42 AM Transmit IR on
8:43:17 AM File.BTVerror [u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test', u'test']
8:43:17 AM Python Script
8:43:17 AM BTV.error_occured u"Adding error: '12'"
8:43:17 AM Transmit IR
8:43:17 AM Transmit IR off
8:43:17 AM Timer: Start new or control running timer
8:43:27 AM Timer.BTVon (0, '4/17/2010 8:43:27 AM')
8:43:27 AM Transmit IR on
8:48:52 AM File.BTVerror [u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test', u'test', u'test']
8:48:52 AM Python Script
8:48:52 AM BTV.error_occured u"Adding error: '12'"
8:48:52 AM Transmit IR
8:48:52 AM Transmit IR off
8:48:52 AM Timer: Start new or control running timer
8:49:02 AM Timer.BTVon (0, '4/17/2010 8:49:02 AM')
8:49:02 AM Transmit IR on
BTV-2010-04-15.log
(292 Bytes) Downloaded 99 times
LogWatcher-Version_1.xml
(3.7 KiB) Downloaded 128 times
ijourneaux
Here are the results with Log Watcher Version 2.
The script correctly idntified the last log file and it seemed to read it correctly but nothing ever happened. I added "test" to the log file twice and "Adding error: '12'" once and the script was not executed.
8:58:58 AM Autostart
8:58:58 AM Plugin: Directory Watcher
8:58:58 AM Plugin: File Operations
8:58:58 AM Plugin: Timer
8:58:58 AM Main.OnInit
8:58:58 AM After init of EG find the latest log file and starts monitoring
8:58:58 AM Python Script
8:58:58 AM BTV.lastLogFile ('c:\\Temp\\LOG\\BTV-2010-04-15.log',)
8:58:58 AM Start last log file monitoring
8:59:33 AM File.BTVerror [u"Adding error: '12'", u'test', u'test', u"Adding error: '12'", u'test']
8:59:37 AM File.BTVerror [u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test', u'test', u'test', u"Adding error: '12'", u'test', u'test', u"Adding error: '12'", u'test']
8:59:58 AM File.BTVerror [u'test', u'test', u"Adding error: '12'", u'test', u'test']
9:00:02 AM File.BTVerror [u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test', u'test', u'test', u"Adding error: '12'", u'test', u'test', u"Adding error: '12'", u'test', u'test']
9:00:17 AM File.BTVerror [u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test6', u'test', u'test', u"Adding error: '12'", u'test', u'test', u'test', u'test', u'test', u"Adding error: '12'", u'test', u'test', u"Adding error: '12'", u'test', u'test', u"Adding error: '12'"]
9:00:18 AM File.BTVerror [u'test', u"Adding error: '12'", u'test', u'test', u"Adding error: '12'"]
I tried restarting EventGhost and loading the LogWatcher Ver 2 script a second time. This time the script refused to execute at all
9:03:37 AM ---> Welcome to EventGhost <---
9:03:37 AM Autostart
9:03:37 AM Plugin: Directory Watcher
9:03:37 AM Plugin: File Operations
9:03:37 AM Plugin: Timer
9:03:37 AM Main.OnInit
9:03:37 AM After init of EG find the latest log file and starts monitoring
9:03:37 AM Python Script
9:03:37 AM BTV.lastLogFile ('c:\\Temp\\LOG\\BTV-2010-04-15.log',)
9:03:37 AM Start last log file monitoring
9:03:42 AM Autostart
9:03:42 AM Plugin: Directory Watcher
9:03:42 AM Plugin: File Operations
9:03:42 AM Plugin: Timer
9:03:42 AM Main.OnInit
9:03:42 AM After init of EG find the latest log file and starts monitoring
9:03:42 AM Python Script
9:03:42 AM BTV.lastLogFile ('c:\\Temp\\LOG\\BTV-2010-04-15.log',)
9:03:42 AM Start last log file monitoring
The FileOperations plug in was upgraded to version 0.1.6 which I believe is the correct version of LogWatcher ver 2.
Take Care
LogWatcher-Version_2.xml
(4.33 KiB) Downloaded 158 times
Now I do not have time to look at it in detail, but now I see a problem.
The script remembers always the last read line.
The next time run, then looking this line at new data.
If it is found, all in preceding lines (including identical) are discarded.
Search pattern is searched in other rows.
It is important that testing conducted with more real data.
Line always begins with a timestamp and is therefore unlikely that there will be two completely identical rows.
ijourneaux
Thanks Pako. The help is much appreciated. Will try with more realistic log entries. and see what happens.
ijourneaux
I just wanted to let you know that after many delays, I finally got the sample script you created working in my application. The script seems to work great. MY first attempt involved trying to use a IR controlled power switch. I couldn't get the power switch to respond to the IR signals from my IR Blaster. So change of plans, Ented up using an X10 power switch. Once I got the X10 CM15A plugin working, I was off to the races.
Took the time to examine and understand the python code you created as part of the sample. It is amazing what you can do.
I was wondering what would be involved if you needed to react to several different error codes; i.e. If Error 12 or Error 41 then power cycle the device.
Really appreciate the effort.
Ian
MediaCTR
Post by MediaCTR »
I am having issues trying to monitor the same file. The script just stops as if it has unmet criteria.
I am using EG 0.4.1.r1534
I have made a few changes to the script:
1) The path to the log file is different. (There are spaces in the path)
2) The error is different.
I am familiar with EventGhost but not Python scripting.
Please see attached files.
Thanks for the help!
LogWatcher-v3.xml
(4.52 KiB) Downloaded 132 times
BTV-2011-08-05.log
(3.08 KiB) Downloaded 143 times
