SunTracker plugin
Re: SunTracker plugin
manjh wrote:Nothing there to configure-.
Close EG and open in explorer:
C:\Documents and Settings\[Username]\Application Data\EventGhost
Move the file config.py to some other location. Restart EG and if everything is fine, attach the old config.py here so we can see what was wrong.
manjh wrote: See attached.
manjh
Post by manjh »
No, same thing.
Perhaps if you could describe what I should do to get things up and running?
I've unzipped, placed the SunTracker folder in the Plugin folder, but from there I am guessing.
jinxdone
Post by jinxdone »
Yes, the installation should be that simple, just make sure you have the __init__.py and the two .png files that are in the .zip file placed in EventGhost\plugins\SunTracker\ directory.
Do you get a window that looks like this when you configure the plugin? If so, have you tried adding the suntracker action/macro, and if that does not work what errors exactly are you getting?
manjh
Post by manjh »
jinxdone wrote:Yes, the installation should be that simple, just make sure you have the __init__.py and the two .png files that are in the .zip file placed in EventGhost\plugins\SunTracker\ directory.
yes, I do get that screen. Then try to add a macro with SunTracker, and that's when the error lines pop up.
manjh
Post by manjh »
am trying to attach a file that shows the errors, but somehow even that is failing. Must be one of those days.
It keeps telling me "extension not allowed". Have tried docx, doc, and rtf.....
jinxdone
Post by jinxdone »
Here, try this version.
Seems like one setting for the SpinNumCtrl (the number boxes in the config dialog) is conflicting with some settings that are normally fetched from the locale. Probably the original author of this plugin did not happen across this problem since it works without modifications in his locale (as it so it happens works fine in my locale also).
-> groupChar = ' ',
-> decimalChar = '.',
Have to be different from each other.. I set groupChar to an empty space in this case.
That should be another bug squashed, thanks for your efforts!
2009-03-15_suntracker_complete.zip
(61.08 KiB) Downloaded 258 times
manjh
Post by manjh »
jinxdone wrote:Here, try this version.
-> groupChar = ' ',
Yes, when I open the macro it now gives me a complete screen with fields to fill in... phew, that's a relief. At least I got my sanity back, was beginning to think I lost my mind.
Now on to the next step, configuration. I've never seen longitude and latitude is this annotation, when I look at my SatNav I get nn.nn.nn, not nn.nnnn.
Hi there,
This is a non-supported version. I have made a newer one with some more functions here:
http://www.eventghost.org/forum/viewtop ... f=10&t=982
But it is still not with the SpinNumCtrl fix, I will look into that and make an update, I have also made some further changes (hopefully improvements)
To get your coordinates, you can use this link
http://www.satsig.net/maps/lat-long-finder.htm
manjh
Post by manjh »
krambriw wrote:Hi there,
Thanks, I found the coordinates. It's only a one-time job (until I move house...), but I would still prefer to enter the coordinates in the usual nn.nn.nn format, like Google Earth does, and SatNavs. Never mind, as long as it works....
But it doesn't! The calculated sun times are: rise 0337, set 1543.
I looked it up in the tables, sun times for today here are: rise 0654, set 1846.
I'll attach a snapshot of my config screen.
manjh
Post by manjh »
Figured it out.... I swapped latitude and longitude.... :shock:
It now comes up with the right rise and set times.
Also looked at that moving ghost option, looks very useful! Can't wait until you fix that bug in there so I can use that version!
jinxdone
Post by jinxdone »
krambriw:
If you want people to use the moving ghost version of the plugin only, could you edit the first post of this thread and put a little notice there with a link to the other plugin thread?
That should help people find the right one to use. :roll:
Thanks jinxdone,
I did that and many thanks for the hint with the SpinCtrl problem! I did not know about that problem...
