the EnableExclusive command sometimes doesn't work if it is executed by the holding macro.
Simply it seems to be ignored, no error message in log.
If i manually click the single command, it is working.
I tested it with other new created folders and macros so it couldn't be the folder/macro itself.
After a system restart it worked again for some time.
Maybe it is a memory problem?
Or any ideas what could be the problem?
stefan
EventGhost Version: 0.3.6.1449
SVN Revision: 458
Build Time: Do, 17 Jul 2008 20:02:01
Python Version: 2.5.2 final 0
wxPython Version: 2.8.7.1
PIL Version: 1.1.6
Platform: Windows-XP-5.1.2600-SP3
EnableExclusive don't work
- Bitmonster
Re: EnableExclusive don't work
Post an example XML.
Please see the attached xml.
Interesting is for example this part of code:
which links to here:
The config is still in process, the rest works very well!
Very customizable!! Great work
Thank you!
<Macro Name="StartTVMode" id="96">
EventGhost.EnableExclusive(XmlIdLink(467))
EventGhost.NewJumpIf(XmlIdLink(468), 2, False)
EventGhost.StopProcessing()
<Folder Name="DVBViewer" id="467" Enabled="False">
<Macro Name="DVBViewer: Start DVBViewer" id="468">
EventGhost.ShowOSD(u'Erfolgreich', u'0;-80;0;0;0;700;0;0;0;0;3;2;1;66;Comic Sans MS', (255, 255, 255), (0, 0, 0), 4, (0, 0), 0, 3.0, False)
DVBViewer.Start()
EventGhost.Wait(2.0)
EventGhost.FlushEvents()
[ ... other macros ... ]
- myConfig_2008-09-25.xml
- (76.48 KiB) Downloaded 107 times
- Bitmonster
EnableExclusive applies the settings after the event is processed. This is to avoid circular behaviour. That's why the JumpIf is not working. You can work around this by using the TriggerEvent action.
Thank you for your hint, now everything works prefect.
Great program - great support as well!
Stefan
Stefan
