Whenever I try to run the games in VMC like solitaire or purble place(my daughter loves this one) with EG running in the background I can't activate the window. It always bounces back to VMC. This occurs regardless of whether I use the software or not. I get the same result if I use the mouse or the remote. I can see the game window in the taskbar but as soon as I click on it, the game window minimizes and VMC maximizes again. I can't even exit the game unless I ctrl+alt+del and close it in the task manager.
Just wondering if anybody else has had this experience or know of a work around. Thanks.
EG conflicts with games in VMC
Re: EG conflicts with games in VMC
If I remove the Task Create/Switch Events plugin then it works, but I can't switch exclusives without this plugin. And the Task Create/Switch plugin is not configure to try and make any adjustments there. Any suggestions?
