Desktop Remote 'Add Button' Event
rjzupko
Post by rjzupko »
Hello, I'm trying to create a custom remote. I want a remote with buttons that would activate macros, or an event within a macro at the very least. I tried to follow the instructions on: http://www.eventghost.net/mediawiki/ind ... top_Remote, but I cannot seem to figure out what to include for the "Event". Is there any way to have it do what I want?
topix
Re: Desktop Remote 'Add Button' Event
Post by topix »
When you add a button to the desktopremote you enter a event name. This event will be fired when you press the button on the desktopremote. The generated event can then be used to trigger macros (use drag'n'drop to move the event from log window to macro in config tree).
rjzupko
Post by rjzupko »
Thank you Topix! The remote works perfectly! I had to add an event to activate the Remote Window for the buttons on the remote to send the event to the log window. I kept on right-clicking and selecting Execute Item to open the Remote Window instead of creating an event to open it. Once again, thank you!
